ALBUM ART on Beo6
Hi everyone!
I got still problem of album art on the Beo6.
3 little album arts are no-problem to came up on the Beo6. But big single album art is not.
I was serching related posts already try it as they posted. But it didn't work.
(Re-install configuration and re set up wifi connection)
Anyone can solve this problem?
What is the standard requirements of 2-way set up?
1. BS5  AUDIO MASTER : YES/NO
2. BS5 MUSIC SERVER : YES/NO
3. BS5 OPTION ? :
4. Beo6 Configuration : BS5 as Audio master?/non audio master?
5. Beo6 Configuration Language set up?
6. Beo6 wifi set up? : WPS/AUTO/MANUAL (Should be same IP address between BS5 and Beo6 (Gohost button in the set up menu)
7. BM5 albumart size?
8. BM5 albumart file? : BMP/JPG/ETC?
9. Other setting option?
Please advice.
Thank you.
Jack.
The version of the CT5.12 that I downloaded from Rapidfileshare made some update of it self via Internet when I logged on with credentials that I got from my dealer. After that the same problem as you have were solved and disappered. Some ghost buttons appeared with the right text and all covers in different sizes now work fine.
My album art is mixed with small pictures and large which are scanned.
Audio master yes, music server yes, the others i haven´t checked.
Brgds Ingvar
It doesn't matter how big the album artwork is. BS5 converts them automatically. If I paste a 600x600 artwork on the BS5 it is blurry. I think it is because of the Beo6.
Hi
Have you read this post?
Re: Beo6 wifi with Beosound 5
//Erik
Hi Erik.
Thank you for your advice.
Yes, I read that post already. But it doesn't work for BIG single album art. (3 little album arts are no problem)
I tried re-install CTtool5.12 and re-set up WIFI connection also.
My feeling that nobody doesn't know well "standard" condition about use 2 way fuction.
Currect posts seems like just posted as they tried before.
So I'm just make sure which is correct.
Jack.
Hi again
I had The exakt same problem. The big coverart not showing and also not sign of any que lists. Did you really delete The complete c:\bangolufsen directory?Not just uninstall? And, of course no, change of language.
//Erik
My problems were exactly the same, inlogging in the tool and it updated itself and after that it was solved. Perhaps I reinstalled between but i dont remember.
The inlogging, is that to Beowise or what can it be? I just borrowed the credentials shortly from my dealer.
Brgds Ingvar
No, I didn't deleted completely.
But I tried new install the S/W another PC and upgraded.
I thought this is same thing deleted completely. Because my another PC didn't installed CTtool S/W before.
I'm gonna try again after work. Let you know.
Thank you so much Erik.
Jack.
How can you get the credentials from dealer?
Is it same like ID and Password for online connection?
If it is, not easy to solve by myself.
Thank you.
Hi again
Just to be clear from my side. I did not update the configtool at all. I used the one found on internet and I got the Beo6 to work - even the ghost buttons are now visible.
//Erik
