a view questions
Hello,
I am new here and i apologize for my English. It is not so good as i wish.
I bought the beovision 7 with BR and a motorized stand.  I also have the configuration tool. I have a view questions.
1.
- I have a  Humax with BIK code and it works fine. When i change the button it still works fine.
- I have a Netgear EVA9150 Digital entertainer. The dealer made a button called DVD2. He choose the BEO dvd2.  When i press the button, the tv is set to the EVA 9150 and i can use the remote from the Netgear. When i change the name of the button in,for example  Netgear the button does not work anymore. So i want to make a new button and i only want the tv go to the aux where the netgear is on. Howe can i do that.
2. Does annyboddy have a template for the Netgear9150
3. I wood like to change the stand of my tv.  Howe can i change it with the Beo5. What command i have to use.
Thanks,
Louis.
Hello Louis
Question two is solved,i hope the Netgear xml file is working fine for you.
About your third question: If i program the avant i get also a stand button.
Regards
Jan
Tank you Jan,
It works fine.
Anyone for question 1?
Louis
