All,
I've had my BEO5 for a couple of weeks now, and I've been trying to get it to directly control a couple of 3rd party products (a Scientific Atlanta HD DVR and a Samsung Blu-Ray player). I've been using a USB IR sniffer to capture remote codes, translating the raw captures to Lintronic raw format, and then using the XML generator to produce 3rd party XML files for the Config Utility. Suffice to say, this hasn't worked and I'm stumped!
I'd be really grateful to hear from anyone who's done this successfully, or from anyone who has advice to give (and the patience to listen to my geeky problem!).
Here are some details:
To capture the IR remote signals, I purchased a USB IR 'Widget' from Tommy Taylor (US $30, here: link). With the IRSCOPE software, (here: ), I can get nice, clean signal captures, showing pulse and pause duration and carrier frequency.
I have a spreadsheet which translates the IRSCOPE .ict files into the Lintronic format (I've tried both the old and new styles). I initially suspected that this was the problem, but I'm pretty certain I'm doing this correctly.
The XML generator produces XML files which don't seem to reflect the pulse/pause data in the file; the log generated seems to 'skip' the pauses, and only read the pulse data.
BEO5 config utility downloads the 3rd party remote codes without error; the signals generated by the BEO5, however, don't match the originals. The general trend is that the signals are much shorter; carrier frequency seems to be correct, though.
I would be grateful for any insight anyone could offer; I'm tearing my hair out!
Regards,
Simon.
