No clock on Beolab 3500
Hi
I recently had to completely reinstall my MacMini. I have Linkplayer and a Beoport. The Macmini acts as mediacenter in the living room - no other B&O devices attached except for the Beoport.
In the kitchen I have a Beolab 3500.
The setup works perfectly (thx to Linplayer :-)), but one thing wonders me - since I reinstalled, the clock no longer shows in the Beolab 3500 😕
The Beoport is set to Option 0 and as I mentioned playing music, netradio etc. works without any problem.
I have tried to reset the Beoport, the Macmini and the Beolab speakers and turning them on in different orders, but nothing has brought back my clock :-)
Any suggestions?
Best regards
Jan
By the way - SnowLeopard 10.6.4 and the latest version of Linkplayer installed and ...it used to work!
Is it still a problem?  I find it sometimes takes awhile.  Like hours even.
Hi
Sorry for the late response - have been away for a couple of days.
Unfortunately it's still not working and it has been on for 5 days now... :-)
The last time it worked, it only took a few minutes.
Best regards.
Jan
LinkPlayer does not send (and has never sent) the clock signal on the masterlink.
I suppose you had an audiomaster before, or a TV on the masterlink.
Try to reconnect it for a while, this should set the clock on the Beolab.
P.
Hi Phil
Thx for the answer. No I never had an audiomaster attached to it. The only thing I can think of, is that i briefly had a windows computer (with the B&O SW) attached to the Beoport. I suppose that might have been it?
If so - sorry for the confusion. Any chance Linkplayer can/will send the information in a future release? :-)
Best regards
Jan
