Mac LION 10.7.2 impacts Analogue/Digital audio (HDMI)
rikarde wrote:
I have tried using the a-pc command, this works for 10 min at a time. I will try some other commands this weekend.
I got A-PC working from the link room - tried it several times, and on the current test we are up to song five, so well past your 10 minute experience.
I prefer using N-MUSIC to A-PC simply because then LinkPlayer sends the track data to my BeoSound 4's display
I am still convinced there was a B&O update for broadcasting digital sound on the MasterLink but I can't find that thread
I solved the problem with only music 5-10 min. I removed the screensaver and the setting that the screen can go to a savings mode. Then the A-pc command worked. But I cant use the a-pc in my link room, when I press a-pc the speaker gets wierd and I have to remove the powercord, then it works correct again. Maybe I have an old software.
I will maybe try a peoport or something again in the future so I can use the n.music and n.radio to get all nice radiostations :)
