Mac - Beovision 10 - BC2
Goodmorning to all (it atleast morning in Sweden) 😐
I have a BV10 that I have connected my speakers, BC2 and MacMini to. The MacMini is connected to the BV with a HDMI cable. I have the TV set to PC and the mac screen appears. Picture and sound is good. I listen to music and movies. SOund out in the Mac is set to: Beovision.
I also want to be able to listen to music without having the TV on. Does enyont know what to do here?
I have tried to connect my usb-DA-Aux in to the BC2 no sound here. I can set the audio out to USBsound. But then I dont get the sound to my BV.. I dont want to change the settings all the time.
When I have the BV set to PC - music out in the speakers I cant listen to the same source in my kitchen..
I have a sqeezebox aswell, I can use that one to the aux, but it takes out alto of the soundquality..
Does anyone have the same problem? Or better a solution :)
Because I have a BeoPort and LinkPlayer software I am ablw to get [N-NUSIC] in the Link Rooms as well as on the TV without the screen being activated
I changed the setup so the macmini uses the command V-mem then it works great in the linkroom :)
