Hi Matthew
The BS3200 will only pass the N.MUSIC and N.RADIO commands to the Beoport. If you want to control other sources in fullscreen mode on your TV, there are 2 possibilities:
1 - You set N.RADIO to MENU. In this solution, you press NRADIO, and the 2 to get N.RADIO, without turning the TV on. Or you turn the TV ON and then press N.RADIO and you get the menu interface, with all the sources to choose from.
2 - You get an IR receiver for the Beoport (they are not the same as for the Beolink active, so make sure you order the right one). You can then set LinkPlayer to react to either PC or V.MEM or the source of your choice.
Beoport should wake up the mac mini when you call N.MUSIC, or N.RADIO or V.MEM...
The problem with the new mac mini is that you have to go to the sound preference panel to change the sound output from the HDMI to the mini jack and vice versa. It cannot output from both at the same time.
In your setup, in the 2nd solution as described above, it would need to send the sound in analog to the Beoport (for N.MUSIC distribution) and in digital through the HDMI (for the PC or V.MEM) usage.
I will try to include a feature in LinkPlayer to make this happen automatically, but it will take a few weeks to be ready.
I would start by the first option a described above, and then when you see the LinkPlayer has this new feature, maybe you can order an extra IR receive and switch to the second option.
p.
