I have a couple of questions:
1. What's the advantage of using LinkPlayer/Beoport over connecting an AppleTV or Mac Mini directly to the back of the TV and using the STB-C?
2. Is it possible to pull video off the Mac onto TV(s) connected to the Beolink system? What connections are needed?
As part of understanding the potentials of my system I have used my Mac in two modes:
Using my Mac integrated to BeoVision as a monitor
To do this I wired my BV8 to my MacBook using a mini-DisplayPort to HDMI cable, and a simple audio mini-jack to RCA cable (this is because Apple does not put audio onto the video interface that drives the HDMI).
I see the Mac OSX desktop, and I use a Bluetooth keyboard and mouse to control my interactions.
I am able to run any application, including using an application's full screen mode. However applications like native iTunes are not easy to navigate at a three metre/ten foot distance because of font sizes and the need to be accurate with mouse clicks.
I have found that it is more relaxing to use media centre applications like Front Row or PLEX, both of which can be controlled by the Apple Remote (the old AR is Infra-Red but a different IR signal from B&O's).
Although this approach is good, it does not allow me to share my Apple's audio with my BeoSound in another room, not with my distributed BeoLabs.
Using my Mac integrated with the B&O audio-visual environment
To do this I wired my BV8 to my MacBook using a mini-DisplayPort to HDMI cable, and a simple audio mini-jack to RCA cable (as above), AND I wired the audio via a mini-jack splitter to my BeoPort, I wired the Mac's USB to the BeoPort's USB, and I connected BeoPort to the B&O environment via the BeoLink MasterLink cable.
In this mode, I use Phillipe's LinkPlayer to translate B&O IR commands from the BeoPort into Max OSX application commands for the LinkPlayer software, or for Front Row or for PLEX.
I am able to now access the music collection on my Apple and distribute around the house, including running Net-Radio and Net-Music on the BeoVision. In particular I like seeing the track information on my BeoSound 4 and on the BeoVision 8 (when it is in PC mode), and of course in rooms that only have BeoLabs I can make use of the voice-over capability that Phillipe added for annunciating key iTunes meta-data.
Some thoughts
I have found that I prefer using the Beo4 via LinkPlayer/Front Row to control a DVD that I have in the Apple's CD/DVD slot, however I am experimenting with capturing my DVDs (particularly my DVDs of music performances) onto an external hard drive and just using the Beo4 LinkPlayer/PLEX interface.
I have also explored the option of directly connecting BeoLabs to the BeoPort: this has the advantage of not needing the BeoVision powered on for listening to music. However I reverted to having no speakers attached to the BeoPort.
I have considered using my Mac only as an Audio centre, and not providing Video support - however I have found that running a media-centre (even in beta-test mode) is changing my viewing habits. I think I will not go back to only watching free-to-air TV nor only using a cable set-top- box. I think I can even see a time when I will cancel my cable subscription if only to escape from advertising.
At first I added a lot of PLEX channels (the BBC's iPlayer is one of these), however I have started removing some channels as I have found them to not be as informative as I had hoped/expected.
I have not succeeded (yet) in getting any video transmitted from the BV8 to other televisions - I think the issue is that currently B&O only supports forwarding analogue signals from a BeoVision's chassie.
I hope that helps your appreciation of the possibilities that LinkPlayer provides.
