Linkplayer CD
Hi, is it possible to use an old audio master (overture/bc2300 link converter) together with Linkplayer and:
1) Have local control of the old audio master and play the CD on the connected speakers
2) Distribute n.music to all linkrooms except where the old audio master is located (both Beolabs and Beovisions)
3) Distibute the CD to all link rooms
/Lars
If you have a tv in the same room as the audio master, and all the speakers in that room are connected to the TV.
Hmm, I'm not able to get this working. Pressing N.Music only sets the Beocenter 2300 in Tape mode. I currently have both the Beocenter and the Beoport in a.opt 0 and in the same room as the BV (with speakers connected to the BV). Am I doing something wrong or have I missunderstod what should be possible to do?
You need the BV in option 2, the Beocenter 2300 in option 0.
LinkPlayer in Option 0, with Vintage Audio Master option activated.
All speaker must be connected to TV.
One can only start N.MUSIC and N.RADIO with a remote.
