LinkPlayer 2 Feedback thread
I had LinkPlayer 2 running for a while, but since a couple of days I have a strange problem:
- when I start N-Music on my BS900 using my Bo4 remote nothing happens.
- when I push go it starts to play music.
- when I then select an album on linkplayer on my computer it starts to play the selection, the previous song remains as well. So, I have songs playing at the same time.
- this does not matter whether I have iTunes running or not.
Anybody who has an idea? I tried several things but without any luck.
Thanks,
Frank.
Thanks,
Frank.
Check if you have activated multiple speakers inside iTunes ... I have sometimes down that accidently, and so iTunes is broadcasting via the WiFi at the same time that the iTunes - LinkPlayer - BeoPort connection is operating
Not sure it explains the symptom you have - my overlap between songs in that situation is just a second or so
And I have just had another thought ... Philippe made a change with LP2 so that his LINK MUSIC playback is not via iTunes but is direct (i.e. it is a different approach between LP and LP2), so I suspect what you have is LINK MUSIC playing as well as iTunes music ... that would certainly explain two different songs, so I think that is the problem
Thanks elephant for the quick reply.
I checked the iTunes and multiple speakers is not activated.
I considered your second thought as well, I have been reading about it in this forum. The thing is though that when I start N-Music on the BS-9000, N-Music lights up, but no music, but when I push a button it start to play. Which, I thinks makes some sense, it starts controlling through the BEO4 LP2. I cannot control that song with LP2 from my computer, but when I then select a song using LinkPlayer it start to play this second song. So, I have two LP2 instances playing. I can control one on my computer (LP2), and one via my remote. Each control independently a song. It does not matter whether iTunes runs or not.
Isn't that weird?
What do you think, is it an option setting on Beoport, BS9000 and beolink active speakers? The Beoport does not have a IR-receiver. It has local speakers. The BS-9000 does not have local speakers connected, but there are beolink active speakers in the same room.
Thanks again
Hi again; I don't normally use LP2 but I cranked it up today to see what I could find ... and guess what ?  I have the same behaviours that you have !
Here is what I tested to create this situation:
  1. LinkPlayer 2 running
  2. I activated its console window so I could check what was happening in the background
  3. N-Music to Beovision ... no problem
  4. N-Music to Bessound ... no problem
  5. Music coming from Philippe's code; iTunes not engaged
  6. Put everything to standby
  7. Started with N-Music to Beosound ... no problem
  8. The only difference between starting from the Beosound room versus the Beovision room is the Beosound takes 2 to 4 seconds to activate, shake hands with LP2, and start channeling the music ... the Beovision is much longer at around 10 seconds before any music appears
  9. Note that ALL I had to press was [N-MUSIC], i.e no (GO) afterwards, but I did have to wait some 4 to 10 seconds
  10. I even tested track skips etc and everything worked fine
  11. Now the interesting bit, reading your note I realised I needed to try [PC] mode on my LP2
  12. This took the LP2 out of standby mode and into its graphical menu
  13. NOTE that this means the [N-MUSIC] did not change the screen menu from Standby ... something that had not clicked with me at the time
  14. I stepped through the [PC] menu selecting MUSIC, PLAYLISTS, RECENT PLAYS, and then starting the song ... some 4 x (GO) button pushes
  15. I then went to the Beosound room and pressed [N-MUSIC] ... and I heard the same song playing overlapped by the time it took me to walk between rooms etc
  16. Again iTunes was not running
  17. But only one LP2 icon was active
  18. Note the difference from LP1 ... the [N-MUSIC] simply connects to the playing source - it does not start a second copy ... and the Activity monitor shows only one LP1 process
  19. So I went back to running LP2 and repeated the test to see what the Activity monitor showed ... still only one LP2 process
So in summary I have the same experiences you have when I try to have [N-MUSIC] in one room and [PC] in the other; with LP1 only one can be active at anyone time, but LP2 is either trying to support multiple simultaneous sources like a BeoSound 4 does (which does not make sense, unless Philippe was expecting the MacMini to have multiple soundcards), or it simply means there is a bug that does not switch off the current source when it gets a Link room command like [N-MUSIC]
I hope all of this helps you somewhat .....
My advice would be to only play [N-MUSIC] options and live with the screen staying in standby mode;
or first switch off the [PC] source before you activate any link rooms
But perhaps with this "explanation" you will come up with your own strategies ... I hope you can find the compromise that works for you !
Thanks elephant.
I don't have a lot of time to do some testing, but I discovered the following, but I cannot reproduce it:
On the link player above the source indicator there is another smaller indicator. I have seen so far 3 words: Source, Link, Distribution. When I play f.i. Radio it shows Link, when it is in standby it show Source, and I once had distribution there and everything worked fine. I could play N.music from everywhere in the house and use LinkRemote. I cannot recall how I got there though. Any experience with that?
Frank
Hi everyone,
Sorry I have been very silent over the last few months, but I have been really busy. Busy at work and busy in the evening working on an other App project.
But things have changed. My contract for my day job has ended in Decemember and my app project is finally complete!
I am taking a few weeks/months off work to concentrate on more app developments, and I am pleased to tell that it's now been 2 weeks that I am back on LinkPlayer and LinkRemote. I am still doing some internal changes to the architecture, so it's going to take a few more weeks before I can release something, but I am now working full time on it.
So sorry again for the radio silence and the unanswered email... but things are going to be moving!
Those of you with iPad and iPhones, have a look at my newest app (The last one in the signature) as it is free until tonight only. I'd really appreciate if, once you've played with it a bit, you'd leave a honest review on the App Store. Without reviews these apps simply don't sell unfortunately.
p.
frammeloo wrote:
Thanks elephant.
Frank
Hi Frank, no I don't think I have seen this.
I just played around with LinkPlayer I and its remote App and I could find no evidence of what you described.
welcome back Philippe, we shall look forward to some new excitements !
I was late seeing your note, so it was no longer free, but when I tried buying it I go a message that your App was being modified, and to come back later :-(
BTW who did the drawings for the story ?
Phil,
It's great to have you back.  I, too, just tried to buy the app ($2 here Stateside) but after one clicks to purchase, there is a notification that the app is being modified and that one should try again later.
I'll be happy to provide a review as soon as it becomes available.
Best,
Thanks for letting me know. We found strange that despite having been featured by apple we had no sale!!!
