frammeloo wrote:
The thing is though that when I start N-Music on the BS-9000, N-Music lights up, but no music, but when I push a button it start to play. Which, I thinks makes some sense, it starts controlling through the BEO4 LP2. I cannot control that song with LP2 from my computer, but when I then select a song using LinkPlayer it start to play this second song. So, I have two LP2 instances playing. I can control one on my computer (LP2), and one via my remote. Each control independently a song. It does not matter whether iTunes runs or not.
Hi again; I don't normally use LP2 but I cranked it up today to see what I could find ... and guess what ? I have the same behaviours that you have !
Here is what I tested to create this situation:
- LinkPlayer 2 running
- I activated its console window so I could check what was happening in the background
- N-Music to Beovision ... no problem
- N-Music to Bessound ... no problem
- Music coming from Philippe's code; iTunes not engaged
- Put everything to standby
- Started with N-Music to Beosound ... no problem
- The only difference between starting from the Beosound room versus the Beovision room is the Beosound takes 2 to 4 seconds to activate, shake hands with LP2, and start channeling the music ... the Beovision is much longer at around 10 seconds before any music appears
- Note that ALL I had to press was [N-MUSIC], i.e no (GO) afterwards, but I did have to wait some 4 to 10 seconds
- I even tested track skips etc and everything worked fine
- Now the interesting bit, reading your note I realised I needed to try [PC] mode on my LP2
- This took the LP2 out of standby mode and into its graphical menu
- NOTE that this means the [N-MUSIC] did not change the screen menu from Standby ... something that had not clicked with me at the time
- I stepped through the [PC] menu selecting MUSIC, PLAYLISTS, RECENT PLAYS, and then starting the song ... some 4 x (GO) button pushes
- I then went to the Beosound room and pressed [N-MUSIC] ... and I heard the same song playing overlapped by the time it took me to walk between rooms etc
- Again iTunes was not running
- But only one LP2 icon was active
- Note the difference from LP1 ... the [N-MUSIC] simply connects to the playing source - it does not start a second copy ... and the Activity monitor shows only one LP1 process
- So I went back to running LP2 and repeated the test to see what the Activity monitor showed ... still only one LP2 process
So in summary I have the same experiences you have when I try to have [N-MUSIC] in one room and [PC] in the other; with LP1 only one can be active at anyone time, but LP2 is either trying to support multiple simultaneous sources like a BeoSound 4 does (which does not make sense, unless Philippe was expecting the MacMini to have multiple soundcards), or it simply means there is a bug that does not switch off the current source when it gets a Link room command like [N-MUSIC]
I hope all of this helps you somewhat .....
My advice would be to only play [N-MUSIC] options and live with the screen staying in standby mode;
or first switch off the [PC] source before you activate any link rooms
But perhaps with this "explanation" you will come up with your own strategies ... I hope you can find the compromise that works for you !
