Hi Phil,
Firstly, many thanks for a great piece of software! I was quite worried when I upgrade to Lion that LinkPlayer was acting erratically, but V2 soon came to the rescue. Clearly, you're ironing out the bugs and lots of us are helping which I hope is helpful. My comments on testing V2 beta1 are:
1. Set-up is a bit confusing and I'm still not sure why despite having a IR eye on my BeoPort that has worked well, I have a red "led" even though I've set the menu to "Respond to Audio and Video Commands only"
2. I'm also not sure I've got my source settings right for a setup that is: In study Mac-Mini - DACMagic - BeoPort (with IR eye) to MasterLink plus local amp and speakers. Then in sitting room on ML Avant linked to BL8000 + BL4000. Then in Kitchen on ML MX4002. Then in Conservatory on ML BS3000 BL6000. I've set the audiomaster as being N.Music compatible then ticked all the boxes. Any advice would be gratefully received.
3. I can play N.Music in all rooms and I love the two source option.However, I use an iPad running Remote to select songs/albums etc. on the Mac and then listen in other rooms, but the music playing is not via the standard iTunes interface, but LinkPlayer is clearly pulling the mp3's from my library. How can I get control via iTunes again as I do not have a video feed from the study to view what's playing?
4. Holding down the Go key gave me the voice-over the first time I tried it but it now crashes LinkPlayer with a loud thump in my speakers. Console dump sent to you via email.
5. When listening to N.Music in Study (direct from BeoPort so Source) and in the sitting room (on ML distribution) if I press red stand-button on LinkPlayer window on Mac the channel selector goes to Standby but the music continues to play in both rooms.
I hope this helps and please keep up the great work!
Best regards,
Rob
