I have followed these threads about LinkPlayer with interest, and since you now have launched version 2, I’d like to give my feedback and hope for a little support as well, as I find this program absolute brilliant, and hope I can make it work on my system.
My setup: Room 1: BV8/26, BS3000, DVD2. Room 2: BC6/22. Room 3:MX7000. Macmini and PC2 in cupboard connected to BV8 and BC6 with DVI/HDMI for picture and analogue sound via audio jack, and Masterlink.
LinkPlayer 1:
I can access N-Music and control it in all rooms. But it is only via BV8 I can use any of the vision commands. It will not respond to “PC” on my Beo4. But as soon as the program has started in “MENU”, I can control it without problems, start PLEX etc. I can’t control it from my BC6.
LinkPlayer 2:
The configuration:
- Beoport connected via Masterlink
- No IR Receiver
- Audiomaster is N.MUSIC compatible (Sources:Radio, CD)
- Mac can access VideoMaster Sources
- LinkRemote & Apple Remote enabled
- I can start the Menu using “PC” on Beo4 - but only once. When I quit using “Q” on my keyboard, it won’t let me start it again. I have tried to program “V.MEM” to start it as well, but it doesn’t work
- I can scroll through the menus, but when I press GO for MUSIC and VIDEO nothing happens. I can then continue to control it on my keyboard, but I have lost control with my Beo4.
Again it is only on my BV8 I have this control. No response from my BC6.
If I press N.MUSIC on Beo4 nothing happens. If I press N.MUSIC with the mouse on the virtual remote nothing happens. But if I press N.MUSIC on the virtual remote with the mouse once, and then N.MUSIC on Beo4 it starts to play and I can control it with Beo4. And I can do that on either BV8 or the BC6.
