Well after several hours of music I decided to go back to the "destructions" and start fiddling again 😂
I found that a looong (GO) will trigger the voice announcement on my BV8 of the track etc etc
But it definetly does not work in the BS4 room
I have got both rooms working which is neat :) the new LinkPlayer support of two outputs means I can have digital (BV8 HDMI) and analogue (BeoPort) outputs
The thing that has pleasantly surprised me !!! is that these two outputs are independent of one another
I can listen to one set of music in link room (s I presume, must test) and another in the BV8 room
[X] Yes, the N-Music works in both types of Link Rooms: BS4 connected, and BeoWireless connected; and controls work in both rooms to manage the analogue source
[ - ] No, switching to [PC] on the BV8 leaves the link rooms running, but scrolling and selecting Videos kills the link rooms' audio 🙁
[ - ] Trying to restart the N-Music in the link rooms got nowhere, so I put the BS4 link room into standby ... this killed the BV8's video playing 🙁
[ - ] Trying to restart the system with just N-Music in the BS4 link room got nothing going ... I then started [PC] on the BV8 to see where LinkPlayer was up to, and it was not at the main menu, but rather an empty "<>" track position under a source of "PC" ... the new icon in the dock also showed "<>" (I sort of like how the icon shows the 'folder' number and the 'track' number, but when I first saw Phillippe's description of the dynamic icon I had hoped for cover art ... bllody users, always demanding the impossible LOL) ... anyhow, the switch of Video certainly has frozen the system so I need to restart LinkPlayer 🙁
Restarting the system still leaves me with a Menu in standby mode, whereas the old Linkplayer always went to populating the menu ... this new behaviour means pressing [PC] once to turn on the BV8, wait a few seconds, press [PC] again to get the Menu display triggered
Also I have enabled all levels of sending the meta data on the Masterlink, and still the BS4 displays "N-Music" but no track info (other than the number)
But I found a LinkPlayer top line menu option called "View" which allows me to set the BV8 to display the cover art of what is being broadcast across the Masterlink to the link rooms ... neat ! 🙂
