I think it's time to start a new thread for the new version of LinkPlayer (V2). What will the new features be and what functions do we want in the new version.
LinkPlayer 2 Feedback thread
Cool, I'll be posting the link to the Beta version shortly. I am doing the last checks. In the meantime, I'll explain what has changed in the interface and in the behaviour.
Not all the features are present in the Beta, but most will be re-implemented if there is a demand.
First is the Virtual Remote...
You can now click on the Track indicator, below the Source indicator, to display a new menu. In this menu, you can access digits, track, random and repeat, but also call the source MENU. When you are listening to an Audio source, the menu now displays inside the Virtual Remote, and can be clicked with the mouse. There are 2 buttons as well to go one level up in the menus or exit the menu.
You can now do more with the mouse and the Virtual Remote.
Note that if LinkPlayer is distributing music to the MasterLink, but the local speakers are not activated, the Virtual Remote will now show Standby.
Secondly is the much improved and logical way of handling changes between Full Screen and the Virtual Remote.
- Sources that are started by a AUDIO key (CD, RADIO, A.AUX, N.MUSIC, N.RADIO) do not go full screen.
- Sources that are started by a VIDEO key (TV, DTV, V.TAPE, V.AUX, PC) go full screen.
You can use the AV key to inverse the effect. Press AV-N.MUSIC to start N.MUSIC in Full screen. Press AV-DTV to start DTV without going full screen. (Press the CTRL key to simulate the AV key when selecting the source in a Menu).
In LinkPlayer > Preferences > Display, there is now just a tickbox for Full Screen : Automatic.
When in Automatic mode, the Full Screen mode will also kick in if you are controlling LinkPlayer from a distance (With the Beo4, LinkRemote or Apple Remote).
In addition, you can force full screen mode at any time from the Windows > Enter Full Screen (Command-F) menu.
Then, there is the revamped Preferences windows.
(So that you know, LinkPlayer 2 stores its settings in a different place, so make sure you reconfigure it completely and re-start it before using it.)
The "General" pane now shows all the different devices in the system, you change the settings for all of them, and a little LED will tell you if something is wrong.
One of the specificities of Macintoshes, which causes a problem with Beoport is that Mac have internal speakers, so when you plug in the Beoport audio jack, you cannot use your Mac speakers any longer. Also, new Mac mini with a HDMI connection behave as they have 2 sound cards, one for the line out and one for the TV screen.
To solve these issues, LinkPlayer will handle 2 sound cards if you have them. This will only work with Internal sources (one more reason to go Internal).
If you have a desktop Mac and plug in an external USB sound card, you can hear your all your normal interface sounds through the Mac speakers, while LinkPlayer can distribute the audio using the external sound card, in the background.
If you have an HDMI mac mini connected to a Beovision, you set the Default sound output (In System Preferences) to HDMI, and set in the window above distribution through "line out", and that should do the trick.
I've tried it but I can't get any of the sources to work. How will I interact with EyeTV, Plex and so on? I think those are in the category Video, but I can't start any video source. If that's the case, first chose video then EyeTV I have a wish a option where you can start EyeTV as before. Because if I want to use the Masterlink Gateway I can't start EyeTV, not in an ease way. Maybe I have to do a macro.
Spotify isn't enabled?
How shall I configure my system. I have the BeoPort with IR-eye connected to a MacMini which is connected to a BV8-40 and a BeoLab 3500 with Masterlink?
[quote user="spezializten"]I've tried it but I can't get any of the sources to work. How will I interact with EyeTV, Plex and so on? I think those are in the category Video, but I can't start any video source. If that's the case, first chose video then EyeTV I have a wish a option where you can start EyeTV as before. Because if I want to use the Masterlink Gateway I can't start EyeTV, not in an ease way. Maybe I have to do a macro.[/quote]
External sources, such as Plex, FrontRow and EyeTV are not yet re-implemented. This will come later.
[quote user="spezializten"]Spotify isn't enabled?[/quote]
Spotify is enabled. You need a Spotify Premium account. Enter your account details in LinkPlayer's preferences. Affect Spotify to one of Keys (A.AUX for example).
