Leopard OS X
The 10.5.1 has been released.
I do not find it buggy at all. But maybe 3rd party apps are incompatible.
Problems I face are:
- Bug when connecting to Airport Extreme disks.
- BM-Link is not yet compatible with Leopard.
If you're not using any of those, I warmly recommend it.
p.
I have it too. Works well with BM-Link the way I use it - with an iPod Touch as remote.
Doesn't like FileVault and Time machine working together. I had a number of crashes and freezes so I turned File Vault off and it seems fine again. I plan to actually do a clean install once I get my new 1 TB external HDD.
OSX 10.5.1 recommended here too. Some apps like GIMP, Java and GrowlMail are still to be updated - otherwise, no issues.
stax
I've had a few bugs.
• Kernel Panics (complete system crash) when clicking the AirPort menu (haven't had this since the 10.5.1 update)
- Dragging icons from Stacks often seems to 'lag' and you end up with the icon floating a few CMs away from the mouse.
- The Finder's sidebar often seems to 'lock up', so nothing changes (disconnected external HDDs still appear etc...), but it can still be accessed.
- Spotlight menu often disappears up behind the Menu Bar, or right off the side of the screen so you can only see a tiny bit.
- iChat glitches (hang ups, complete crashes, keyboard unresponsiveness etc...)
- Keyboard stops working completely, no caps lock light, no num pad light, nothing, almost as though it's been disconnected (this is on a MacBook Pro). Only happened for the first time today, but a friend of mine has had the same problem quite a lot with a brand new MBP.
There have been other issues, but overall it's not as bad as lists of bugs make it out to be. In fact it's very very good. Much faster than Tiger (by miles), and the new features are great! I'm not really finding the bugs to be any major issue (there are workarounds for most of them).
I also sometimes have iChat crash completely, but the windows etc.. stay open and look normal (even the text cursor keeps flashing) but I can't type or receive/send any messages, or scroll around.
It's also crashed a few times when sending files...
one thing i hate about leopard is the search / spotlight and the way it displays results
eg ; do a search for items larger than say 100 megs , the results aren't viewable by size !!
basically you can search for things but are very limited as to what criteria you can sort them by
not impressed at all by this tbh
