Do not hesitate to ask for some help using the procedure on this page:
Help in configuring mac mini, Beoport and Beolab 3500
That`s what I was waiting for.....😁
But please tell us how it goes on.....
Stefan
That's allright - could easily be something simple :-), but yes the sound is set to absolute max on the mac mini. Tried to connect headphones and there was no problem.
I also checked the wiring and to me it seems okay. I used to junctions boxes.
It's also a bit strange, that the Beolab seems to be a delay in reacting to the infrared commands from the Beo4.
I'll try the other sources.
@Phil: thanks Phil - I post the questions that way around also.
Best regards
Jan
Just sent the Console listing to you Phil :-)
Best regards
Jan
It is a problem with LinkPlayer in option 2 that I knew happened with the Beolab 2000. I think the issue with the Beolab 3500 is the same.
There will be a fix at some point.
Hi Phil
Sounds great - do you have any time estimate? 🙂
Best regards
Jan
The new 1.1 version should fix this problem.
p.
Have I missed something?
Didn't the beoport module need a beosound 4, 3000, 3200, 9000 or BC2 to function properly?
When used on a PC with Beoplayer, or a Mac with LinkPlayer, you can use the Beoport as an AudioMaster.
In addition, with LinkPlayer you can use the Beoport with incompatible music systems, BC900, BC2500...) in certain setups.
Nope - works fine for me with just the Beolab 3500 connected and the Beoport set to option 2. :-)
Best regards
Jan
