How can I connect my iPhone to my Beovision 10 and watch e.g. music videos from YouTube? Any idea?
Thks in advance
Soren
Thks in advance
Soren
Easy! 🙂
Apple TV
Easy! 🙂
Apple TV
correct ... exaxtly what you can do (e.g. mirroring) depends on the precise model of the iPhone, but in general:
iPhone ))) airplay ))) ATVg2 ==hdmi == BV10
Thks a lot. It's an iPhone 3GS plus Ipad2. So I need to invest in ATV?
I use a 3GS, my wife a 4S, and we have an iPad gen 1.
So only my wife's phone can be used for mirroring iPhone game play onto our ATV gen 2.
For all other work (so far) we have had good success, and yesterday I installed and integrated an ATV gen 2 for a friend who is a forum member.
His iPad gen 1 also worked - in his case the TV was a BV 7-40.
So I believe that an economical solution is the ATV (gen 2, and there are rumours of a stop gap gen 3 before the equally rumoured arrival of the Apple proper TV).
An ATV gen 2 is US$99, and AU$129 -- a very good deal.
But beware :-) if you are like us your iTunes bills will start to rise (movie and TV show rentals) as will your bandwidth consumption (endless YouTubes).
Installing an ATV gen 2 can take all of 10 minutes ... plus another 20 minutes to do an update over the network to the latest version of the operating system.
It will give immediate internet access to iTunes movies (we love watching the latest trailers), TV shows, YouTube, Flickr, internet radio and so on.
To purchase any iTunes materials you will need to add your iTunes account and its password.
Integrating the ATV can take longer ... depending upon what you want to do:
All that took Cliff and myself about 3 extra hours.
If you send me a free plane ticket I will do yours too 😂
Are you sure about your 3GS? Because I have no problems to mirror to my ATV2.
However my 3GS, as my ATV are jailbroken, but I thought it should work also with none-jailbroken devices.
Just to be sure we are being precise with our terms ...
Sorry for being so long winded and pedantic, but hopefully it clears up any confusion -- or helps you guide me to a solution :-)
No need to be sorry! 🙂
I can Airplay all media, including video's and photo and music on my iPhone 3GS. Airplaying a Youtube movie from my iPhone in HD to my ATV still gives the 720p picture. (I thought it might be downscaled, but it isn't)
However, I can't mirror the springboard of my iPhone. Nor the apps that are not multimedia related. Only the apps that support Airplay. Indeed it is not exactly mirroring how you meant it. This is only for the iPad2 and 4S.
correct - to use the first level of AirPlay the App must use standard audio/video media APIs or functions.
The mirroring I described is an operating system level transmission of what is on the screen (bit for bit) - and must need more power (CPU/GPU) and that would be why they have restricted it to the latest hardware platforms.
With mirroring there is a small lag, so while you can play games like Bean's Quest (shameless plug 😂) the player inevitably refocuses to what is in their hand for fine motot control - while the audiance can track the player's progress on the BeoVision
