Just browsing through the BV8-40 user guide which states on page 16 (titled "Use your television as a computer monitor") that it supports the following screen resolutions: "60 HZ; 640 x 480, 800 x 600, 1024 x 768, 1280 x 720." To my surprise, the ideal screen resolution of 1920 x 1080 seems to be missing from the listed supported screen resolutions here.
Does anyone know why the display's native screen resolution would not be supported by the BV8-40 when connecting it with a PC? Or is it?
I think that's just because the BV8 40 user guide was simply (and wrongly) copy-pasted from the BV8 32 user guide ;-)
I get more options than that from my MacBook and BV8-32.
I get sharp computer text on options like 1280x720, but I also have a 1080i option which does not yield a good "pc" monitor picture, but is good for playing movies via the MacBook ....
Have you checked that your Mac recognises the BV8? Mine does .....
