BM-Link and iTunes 10 - do they work together?
Hiya,
I haven't updated iTunes on my mini in a loooong time.  Does iTunes 10 break BMlink?  Or do they work happily like... uh... two things that work together?
It doesn't like the Beosound plug in but once this is removed, it seems to be fine. Mine is working perfectly.
I have tested for you my iTunes 10 (without the BS plug in) with BMLink, and "good news", it still works
Sorry to be so ignorant but what is a Beosound plug-in and how do I get rid of it?  I have recently converted to an imac and am experiencing similar problems with Beosound 2
when itunes crashes it produces a crash report and asks you if you want to reopen it ...
buried in the crash report text was the location and name of the offending plug-in, here is where mine was
PlugIn Path:       /Users/ed/Library/iTunes/iTunes Plug-ins/BeoSoundPlugin.bundle/Contents/MacOS/BeoSoundPlugin
I copy and pasted "/Users/ed/Library/iTunes/iTunes Plug-ins/BeoSoundPlugin.bundle/Contents/MacOS" into the Finder Go To Folder menu
/ed/ is my signon, yours will be different but the rest should be the same
Once the folder was opened I then moved the plug-in to an archive spot ... leaving the other plugins there as they were not an issue
The system will ask you for system administration approval to do the move by asking for your password
Then you can reply to the crash report reopen option and itunes will restart perfectly
