BM-Link 1.5
The IR Receiver might be just fine. I once bought the special version for the PC2 and noticed that while the lettering was missing it had the full functionality. It is more a matter of the cable and connector. See attachment. Regards Harald
Try it with your keyboard and press APPLE + ESC. Then Front Row should start.i need your help:got a powerbook g4 with frontrow enabler. i will connect my beoport via my beosound 3200. but frontrow doesn´t work!!!! do i need the ir eye?! or must i do any changes in my 3200 to get the mac and the beoport to work?!
Try it with your keyboard and press APPLE + ESC. Then Front Row should start.Coolblue86:
hello,i need your help:got a powerbook g4 with frontrow enabler. i will connect my beoport via my beosound 3200. but frontrow doesn´t work!!!! do i need the ir eye?! or must i do any changes in my 3200 to get the mac and the beoport to work?!
Does anyone know any kind of IR-repeating hardware to get signal of my Beo4 in others rooms sent to the IR eye in the office?
(It's not possible connect 2 IR-Eye in the same socket of beoport.)
Yesterday I bought a universal Ir-repeating, but it doesn't work with beo4.
Luis,
What is the reason you cannot connect multiple infrareds on the beoport? Is it because an interference will occur? Maybe a simple solution is to put a diode between the signal leads of each infrared? If you would add a lot of infrareds I think it will drain to much power from the beoport. But you can ask a dealer or a technician to work out a small diagram.
Matt
I thought use a minijack (headphone) splitter (stereo), but the technician said it's would cause same error o conflict.
Anders recommended a IR-repeating, but i don't know any IR-repeating B&O-compatible.
Try it with your keyboard and press APPLE + ESC. Then Front Row should start.Coolskin:
d: TT-IR-1455 is a miniature thumbnail (B&O) 455 KHz infrared receiver. (very limited IR range)e: TT-IR-8087030 is a plasma-protected (B&O designed) 455 KHz infrared receiver.
