BM-Link 1.5
Luis,
Seeing the pictures on your site, there is indeed an easy way to solve the problem.
If Odlund would add one extra option in the BM-Link, namely that you could choose the default interface: ITunes or Frontrow we have the (mine...)problem solved.
If you choose as default interface: ITunes, everything works as version 1.5, so N.MUSIC and N.RADIO are selected using the ITunes interface.
If you chooose as default interface: Frontrow, (and have the video of the mac connected to a beovision) you can select PC to get video on the beovision. To scroll through the interface and get/select sound or select IPhoto or Quiktime Movies you have to select A-N.Music
If you use a converter to get the video signal from component to RGB, you can even get all the features in link rooms with tv!
Odlund will this work, or is this easy to implement?
Regards,
Matt
Hi Matt!
The new software works perfect! No need any changes.
If you press n.music/n.radio, you get n.music, n.radio through iTunes. If you select fullscreen in coverflow of itunes and the video of the mac is connected to a BV master, pressing V.Tape/V.Mem you can watch the coverflow of itunes, and pressing A-N.music/A-M.radio (new Beo4) you can control it.
If you want control Frontrow in a BV (master o link), you need 2-3 IR-eye connected directly to the beoport. It's the only way. The beovisions doesn't accept the PC command, only the beoport.
I am going to buy 2 IR-Eye. This is the solution.
I thought I could have sound when I select v.tape. I have connected a video and stereo rca wires to BV3-32.
Hi Luis,
I agree, this solution will work, albeit that if Odlund would add my suggested feature it saves a lot of infrared eyes and cables.
Question,
How did you succeed in distributing the video signal to the other tv's?  The modulator in the BeoVision is not able to distrubute a component/DVI signal of the Mac. I saw all kind of suggestions, but maybe there is an easy way?
thanks
Matt
Hi Luis
You have another choice like v.tape2, dvd2, v.aux.
Luis,
might be I'm thinking in the wrong direction: I have a Mac Mini connected via DVI with my BV. If  I want to display Itunes, I use the screen in the PC mode. Pressing any of the buttons you have mentioned would switch the BV to the Tv (pal) mode and no longer display the computer signal???
francis
I would like to get an update on this beoport matter. I have never been able to figure out how this setup is done. In my opinion the B&O usermanuals are dreadfull, regardless of product.
Well, what i need to know is this:
I have a BV 7 in my livingroom, connectet through ML to my BS3000 in my living room. In my bedroom i have an Imac, not connected to anything YET. SO, if I buy beoport and set this up in my bedroom what will i need to get it working? Sofar i have figured this out(at least i think i have)
1: I set up the beoport box in my bedroom, connnected to my Imac through USB and an soundcable.
2: I have no B&O equipment installed in my bedroom so do not need speakers there to be connected directly to beoport. How do I get the sound from beoport to ML system in my livingroom, through ML??
3: Further, when everything is connected propperly, can i then control beoport througt the IR eye in my BV 7?
Found an old PC2 manual but cant seem to figure it out??
Can anyone please help me understand?
So, if you want display mac on BV7 press PC. For a link beovision press v.tape. I suppose it will work fine. But I don't know. I don't own a BV7.
Hi Ehlerz
1) Exactly.
2) Yes, You need a long ML cable.
3) Yes, you can control beoport througt the IR of BV7 (video option 2) but if you add the IR eye you can control the beoport in your bedroom. Only the IR-eye connected to beoport accept the pc command. So, you will control the Frontrow on your iMac.
