Very nice work on version 1.5.
The extra features are very nice, such as the N.RADIO, and Frontrow
Just a question about my setup: I now use beoport to distribute N.MUSIC and N.RADIO. Using ML it is available at all B&O systems.
Ultimately I was hoping to use beoport to control frontrow (I now can), but also to control it on all systems (I cannot, because the infrared must be connected to the beoport)
My idea is to use my Beovison 7:
-To distribute the video from the Mac using the build-in modulator in the BeoVision 7. I need to convert DVI/component signal of the Mac to RGB (The modulator cannot distribute HDi signals). So the video signal will go into the BeoVision 7 by using a scart and assign it in the BeoVision setup to "PC"
-Beoport (with no infrared attached), will be used to control the Mac and to distribute sound using ML.
In above setup you have video and music in every (link) room.
Of course this setup will not work, yet? Is it possible to program into BM-Link an extra feature so that this setup works?
The only obstacle is that frontrow should be controlled sameway as N.RADIO and N.MUSIC.
Matt
