yes that is right. also i do not have any other documentation than the brief one B&O supply.
thanks
thanks
Now, with regards to the login problem, please do kindly try the following:
Go to your Windows 7 implementation running in Parallels Desktop V5.
Make sure the network connection is bridged, not shared.
Open the command console (Start / type cmd in the Search programs box / hit Enter).
write PING plus the Beomaster's IP-address (e.g. ping 192.168.3.15) and hit Enter.
The program will now ping the Beomaster and supply back a delay time of anything between 10 and 200 ms.
Tell me if that worked for you.
Hi
I am back i did the ping test: 4 packages sent 4 received no loss
min: 5ms max: 881msec average:380ms
hope to hear from you again;
thanks
Great, now I would like you to do exactly the same, but not limited to ten pings:
1) Go to your Windows 7 implementation running in Parallels Desktop V5. Make sure the network connection is bridged, not shared.
2) Open the command console (Start / type cmd in the Search programs box / hit Enter).
3) write PING plus the Beomaster's IP-address PLUS the parameter -t, pipe it into a file, e.g. myping.txt and hit Enter.
This would look for example like this: ping 192.168.3.15 -t > c:\myping.txt You will notice that nothing happens - which is not true: The ping command is running until you decide to stop it using Ctrl-C, and the results are not displayed on the screen, but are redirected into a file called myping.txt which will be created in the root directory of your startup drive.
4) Leave this ping running for at least 30 minutes, then interrupt with Ctrl-C, open the file and look out for irregularities. You may also send me the file via private message if you want.
(I hope I do not bore you with these detailed instructions but I want to make absolutely sure that the IP link is ok. Also, I do it from Windows, because if it works from the Parallels VM also the Mac's base IP socket connections will be ok.)
Hi stefan;
I tried the ping -t command but i keep on getting acces denied!
thanks
OK after trying many things i finally have the answer: Beoconnect does not work and needs an update soon!! meanwhile i can connect to the beomaster thru:
1) connect to server
2)smb://ip adres of beomaster5
3) type in the window for verification: name:beomaster5\BM-USER
passw: your assigned password.
4) connect and voila you are in and will see the hdd icon on the desktop with all subfolders; copy your itunes library to music folder.
hope this will help other mac users.
thanks
Hi Kaz
Good work! I am glad this worked out for you!
Best regards, Stefan
