BeoCenter 6 and Mac Mini
BeoPort is a box sold by B&O which acts as a bridge between B&O and your computer. Connecting an IR Eye to it allows it to interpret the commands from your Beo4 remote, and the software from Anders called 'BM-Link' now supports the ability to control Front Row through the device.
Never tried it myself, but the response seems very positive!
Check the thread at the top of this forum area. 🙂
It's a very compact box, think something like a large box of chocolates (mmm) or a small shoe box.
You might also want to look into IRTrans/iRred with the Beo4VRC. Gives you full control of a series of app's.
Hi soundproof, you are right. Since may this year I use beo4vrc to control
- MediaCentral
- EyeTV
- Front Row
- iTunes and
- iPhoto
and it works great. I have installed two irtrans modules, one in the main room, the other in the sleeping room.
In this way I control the mac from both, the main and sleeping room. The mac is connected to a beovision 6.
In the main room I use the PC option and in the sleeping room I use the V.Tape option of my beo4 remote control
to listen to music and watch video placed on my mac.
Greetings
ppcmac
for the beoport, as far as i know the bm link solution does not support fastt scrolling which may be a bit of a problem depending how much content you have.
IRTrans/Ired don't either, hoever you can workaround a bit.
JK
