soundproof
I have my NAS (2TB) already so I'm to the get step. I might just have to purchase it ad see how it works.
JK
The NAS does should show up as a Shared or Network Storage.
soundproof
JK
No coverflow though. Check out the media streaming section in the infrant support forums.For movies it doesnt do that yet, however this is not super critical since Front Row pulls in whatever is in the movie folder, even if there is an alias inside, it follow its path.But for TV Shows, Itunes would be very nice though.
If you set the library path for iTunes to the media folder on the ReadyNAS, then you get coverflow functionality, as the mac just treats the NAS as an extra harddisk.
The server also shows up as a resource under SHARED, but I access it from the main LIBRARY section of iTunes.
You're right as to Movies. I open those using VLC for playback (which I consider a superior platform to QuickTime for many kinds of files I'm watching).
Can any explain the manual for the Beo4VRC Software to me. I have used google translater but it seems to be missing some key points during the translation. I'm currently trying to activate it to use Media center
Thsnks
Brendon,
I could try to help you with the translation. You should send me your document via PM as I'm not shure to have the same version stored here on my computer.
However, the first thing I would suggest is to contact the programmer. It is not unlikely that he already has an English version. For contact details see the "Impressum" on his
@Francis the creator of the Beo4VRC software has not email ime back and its been week.
Anyway, I have question do you know if I must have an IRtrans to make MediaCentral work? Here is my current setup:
Mac Mini PPC (no IR)
Beoport
Bang& Olufsen IR Puck plugged into Beoport
The new BM-LINK that I can control Front Row with Beo4 remote
Do you think I can purchase Ired Software only and have with in this set to control Mediacentral with help of Beo4_VRC? Or do I have to purchase the IRTrans LAN control in order for this to work?
Basicly will the B&O puck remote work for me in these instance.
JK
I have applescript written that does not require me to use Ireds. No additional hardware required :)
Brenon
