Just got Apple tv installed, - the Beo5 will not turn it on, is this normal.
Should I leave it on all the time, or do I have to use the Apple remote to turn on and then use Beo5 to control.
my experience is with the new apple TV and a Beo4.
I had to unpair the apple TV from the remote that it was shipped with and which I had used to install and configure the apple TV.
Once I had done that, the apple TV responded to the signals the PUC sent (that were triggered by the Beo4).
Unpairing is a configuration option inside the menu of the extreme right hand side of the apple TV's main menu screen.
Thanks elephant, will give that a try.
That seems to have solved the problem, thanks Elephant.
