Apple TV and Beovision 8-32
I have a Beovision 8 and Apple TV. I had the tv upgraded with AppleRemote in the STB list. I have connected the Apple TV through a HDMI- cable. But I can not get the Beo4 to control the AppleTV....
Any ideas???
Best Regards
Lars Chr Jacobsen
can you post details, I have it working. I.e. what source you are using, what port the IR connector is linked to, STB version ..... I am in the US, it worked out of the Box on the 32". Is "AppleRemote" the STB controller you selected? Mine is called "Ipod Remote". it works including fast scrolling.
Cheers
JK
Hi
I have it connected to AV3 through STB(V-AUX). I gave selected IR-port C2 and HDMI. I have got a decoder connected to DTV in IR-port C1. The STB controller I selcted is "AppleRemote". That is my only option. The B&O serviceman who wisited me, only uploaded the controller I needed for my decoder and AppleRemote. I have tried to see the signals from the IR-blaster through my cellular camera. I can see i transmittes something, but the signal seems weak. I have tried to switch from C2 to C1, but nothing seems to help. But maybe i have to get him to upload "Ipod Remote" instead.
Best Regards
It seems the STB versions are locally different. They do not store all devices but only what is common in a country.
It seems a bit chaotic. I.e. here in US t was working perfectly but nobody did know. I asked Beocare and it toook them long time to confirm but in the end they did.
So maybe mention that it is working with the US BV 8 32 and the Ipod Remote.
JK
Hi
Had my B&O Serviceman on a visit today, and installed til iPod remote software. It worked!!!!!!!
Thanks a lot!
Best Regards
But now I have encountered another problem. There is virtually no sound in my Beolab3500 when I choose V-AUX. Could it have something to do with the fact that I use a HDMI-cable?
 Lars Chr
