Hello Beo/Mac enthusiasts,
Last week I projected myself into the digital world…BV-10-40 & Satellite STB were installed
Only a few years ago I still was watching analog TV with a rooftop antenna, and had to switch to a simple Standard Definition SAT receiver because air broadcasts simply stopped…(I live in the countryside, no cable access)
Now I have to dig into all the possibilities my Rebox HD9000 PVR has to offer, and figure out how to control it with the Beo4 🙂(a Beo 6 is due in somewhere this month).
But the fun part started when I hooked up an Apple TV 2 (black) which I picked up in the USA about a month ago.
As I expect from Apple products, connecting it was very simple: powercord, HDMI, switch on, WiFi network password, switch on homesharing for iTunes, and voila: Streaming podcasts or iTunes content from my iMAC thru Airplay….IPTV is added to my set-up in a matter of minutes. Great!
Correction: limited IPTV, because ATV2 is not supported in the Netherlands, so no nice services like rent-a-movie yet, and the video formats supported are also very limited. Nevertheless, I am impressed, and this for only USD 99.
But after approx. half an hour: no more connection to my iMAC…🤔. after reestablishing homesharing again connection drops after some time. Did quite a bit of searching on the web, only to find out that it's a common problem, you either have no issues at all, or you keep losing the homeshare. Apple support points towards firewall and router settings: opening a number of ports on the router would do the trick.
I have been trying this, but can not get it solved. Opening ports (for timeserver: TCP123, bonjour: UDP5353, libraryshare: TCP3689) does not help. I finally hooked up the ATV2 to my network with an ethernet cable, and it appears stable for now.
I would like to get the WiFi streaming working however…so any advise is welcome !
I am also very interested in ATVFlash, so all hints & tips are welcome, but first I want a stable airplay...
Greetings
