Apple TV - Using one with an Standard Def TV
RGB + Audio stereo to Scart
Gracias Luis, pero yo no entendo español.
If I understand correctly. The cable from the link you provided will input Audio and RGB to a SCART equipped TV for just under 9 euro's.
Is not the Apple TV equipped with Component Video rather the RGB out? If this is the case one would first need a Component to RGB converter and I am sure those don't come cheap.
No, they aren't
View the first post in the thread to see. There is one there which will convert component to RGB and goes straight into the scart input, as well as carrying audio...
excellent review of appletv
