Apple TV - Fast Scrolling Stopped working
Has any noticed the fast scrolling not working on the Apple TV when using the Beo4 remote?  I loaded the latest firmware version of the Apple TV but I not 100% if that why its not working now.  I have it connect to a BeoSystem 3.
I have the latest ATV version as well, with BV8 though. Maybe you paired the Apple remote by accident? I had no issues after the upgrade.
 Cheers
JK
JK
Can I unpair it? if so how?
It would be on your Apple TV under settings - general - remotes ...
Unpairing Apple TV with a Remote
If you lose the Apple Remote that you paired with Apple TV, you can use any Apple
Remote to unpair Apple TV from the lost remote by pressing and holding MNEU and <<
for 6 seconds. You can also follow these steps.
To unpair Apple TV from a previously paired remote:
1Choose Settings from the Apple TV main menu.
2Choose Unpair Remote.
When you’ve successfully unpaired the lost remote, Apple TV displays a broken
chainlink ( ) symbol above an image of a remote. You can now pair Apple TV with
a new Apple Remote.
Pairing Apple TV with a Remote
The Apple Remote works with the built-in IR receiver on Apple TV. You can set Apple TV
to work only with the included remote by pairing Apple TV and the remote.
To pair Apple TV with the included remote:
2Choose Pair Remote Control.
You can also press and hold » and ‘ for 6 seconds to pair Apple TV and the remote.
Thank you both for the info.
