looks interesting
Apple release new Mac Mini with HDMI !
looks interesting
Indeed it is.
Resolutions beyond 1080p through two interfaces.
HDMI with audio and still retains the optical mini-jack option.
And an SD card slot (but at the back of the machine).
My only disappointment is that it remains a core duo machine with a small speed bump and a moderate disk upgrade.
A lot of surprise in the Macrumor forums over the USD100 price increase.
Come on: This machine is faster than what 95% of the population need. Actually I think for any usage as a kind of media center it's more overpowered.
Christof
Indeed it is.
I am kind of attracted to it, I might replace my Apple TV with it since it can do so much more and can be controlled from my BV8 and Beo 4.
Christof
My concern Christof, is should I just have it as a server ... and get something else as the end-point media interface ?
I would be a lot happier if I new the specifications of the rumoured replacement for the Apple TV.
What was at the back of my mind when I was writing my first set of comments was the new MacMini playing a 1080p movie and then recieving requests from other users for large files ... should I be planning for a separation of duties ?
First of all, I strongly recommend the Apple TV as a device to bring your iTunes content (local or on the store) to the B&O world. It is very B&O-like: You just plug in the power chord, the HDMI cable, and the PUC cable, and everything just works. No software installation, nothing. Plus it is SO much cheaper: 260€ vs. 800€.
The new Mac mini is a strange beast to me: Yes, I like the looks a lot, and the specs are also great. But 800€ for JUST a basic computer? The previous model was ok (started at 600). Remember that you will need additional RAM, a keyboard and a mouse, and you will still not be able to enjoy the (to me) beautiful UI of the Apple TV.
This being said, I unfortunately cannot tell you whether the CPU of the new Mac Mini is capable of decoding Full HD and serving large files over the network at the same time. I assume this mainly depends on the Codec used for the movie file.
I actually agree with your recommendation; I am just waiting to see what form the rumoured ATV 2.0 looks like. If it appears in the form of the rumours I think I can see myself buying at least 3.
I am in the "lucky" position that I already have an bluetooth Apple keyboard and two bluetooth mice. One consideration you have not mentioned which is probably important for me is heat - my hand-on-the-top test indicates that an ATV runs hotter than a MacMini, and I think the new one should be cooler (certainly it takes less power).
However you are right (and I had forgotten) that the ATV 1.3 interface is better than the Front Row that I have today (and which I associate with the ATV). But on the other hand I am a proud user of Phillipe's LinkPlayer . . .
I found this post a very useful analysis of the difference between the various recent announcements:
" Remember that you will need additional RAM, a keyboard and a mouse".
A keyboard and mouse will not be needed if you have an iPhone or iPad, you'll just use apple remote as a track pad and keyboard. However it doesn't look like the new mini has an IR, so maybe no PUC control. Hope I'm wrong on that front.
PUC should be fine, IR remote is listed is accessories.
It runs on 802.11g and still there are no hiccups in the EyeTV streaming. While playing iTunes on the B&O through BeoPort and ripping a DVD.
Long story short, there's nothing anemic about the new Mini. It'll do everything you want in home entertainment.
