Advice on MacMini, BV7, Masterlink integration
Hi Cliff, as I drove away I kicked myself ... we should have left the analogue audio cable in from the MacMini's headphone port to the BV7 because we will need to reconnect it later ...
clifft wrote:
There is also an issue with N Music and N Radio playing easily when the tv picture is on but not when off.
When the picture is on, the MacMini and the BV7 are in synch ... they are both using the HDMI connection for the audio.
When the picture is off, and N.MUSIC/.RADIO are selected the BV7 is looking for an audio analogue signal ... but the MacMini is still broadcasting on the HDMI.
The approach that Philippe and I are working on is to have LinkPlayer automatically switch the MacMini's audio between digital (HDMI) and analogue (the cable we tried and then removed).  This will be the program-driven equivalent of what you and I did yesterday ... change the MacMini's System Preferences -- Sound from headphone to BeoVision 7 HDMI - and get analogue all you need to do is switch BeoVision HDMI to Headphones ... with the cable we removed plugged in !!!!!
clifft wrote:
Also, I transferred some of my iTunes from my iMac to the iTunes of the Mini and they came across well but when I tried with a few more, even though I placed them in the same music folder they don't show up!!
To move the music across you need to update the MacMini's library data base ... and how I did that was to do an import of the files under the iTunes File menu option of "Add to library"
I suspect you used Finder to copy the files ... we need to do both the files and the data base.
The easiest thing is delete the files you copied, and then do the "Add to library" process
Thanks, Ed.  I did as you suggested for the iTunes and over they all came!!  In fact, everything came over including my Podcasts and Movies!!  I had to wait ages for it all to go through!!  I find I can open and play films and tv programmes in the same way as I do on my iMac but apart from those you put across on saturday, I can't find the others on Linkplayer or Plex.  Obviously I am not putting them across into the correct place!!  Looking at the instructions for the BV-7, it clearly says you need an analogue feed to a link room.  Does that mean I am stuck with Composite and the interference I am getting?  If so, it will be a real disappointment having spent all that money to have an inferior picture in my link room!!  Cliff
Well you had at least 6GB of music :-)
You may recall we set up in the "Movies" home directory of the MacMini the following sub-folders/directories so that LinkPlayer's video, Front Row, and PLEX would find them:
  1. "DVDs" for the DVD you had captured in VOB format ... those you will have to continue to drag and drop to VLC since it seems to understand the DVD menu structures; when I rip my DVD collection using Handbrake I don't transfer to VOB, but instead I transfer to a single file, for example my Andrea Bocelli's Tuscany performance is a single 1.23GB *.m4v file (whatever that is!); I have even duplicated some captures using a package called MakeMKV that produces *.mkv files - I believe these are more akin to a full DVD structure except they appear as a single file and unlike the *.eyeTV files they cannot be "opened" and drilled into to find the actual video segment; to be honest I still have not worked out what is the right/best capture method - *.m4v produces smaller files, however I suspect that *.mlv gives me the ability to have subtitles and/or multiple audio channels ... but I don't have a surround sound set-up like yours so I can't confirm this
  2. "TV Shows" (I think) for the TVs shows you have recorded/captured (e.g. the two Tudor episodes) - here we created further sub-folders so that PLEX's synopsis and thumbnail processes would work
  3. "Films" for films you had recorded ... e.g. the "Mo (2010)"
  4. "EyeTV Archive alias" which points to the EyeTV recordings directory
Note that if a "film" or a "show" has a file name that does not match IMDB or TheTVDB respectively then the PLEX Movies menu or the PLEX TV Shows menu will not show the recordings.
Also note that even if the filename does match the IMDB / TheTVDB patterns you may need to type "C" when you have the source highlighted in PLEX's Videos menu in order to request a "Scan for New Content" so that PLEX discovers the material you have added.
Yes, this is correct ... that you need an RF feed that carries analogue video and a MasterLink feed that carries analogue audio.
However the Moire interference patterns you are seeing may simply be caused by an incorrect set-up of the B&O RF amplifier that was installed somewhere that we never found !  So I would wait until Graham's visit before deciding whether there is or is not a real problem in this area.
clifft wrote:
Well, you have read my saga so far of my new BV-7 on the main site.  The Mac Mini is faring much better.  The boys installed it to the back of the set but couldn't get a picture!!!  Much fiddling around plus a phone call to Ed didn't help at all plus they were getting more and more tired after a frustrating days work.  Then, they discovered they hadn't plugged the HDMI cable in!!!  Success at last!!
Well, I've now got my BV7 III (thrilled with picture quality) and now the Mac Mini has arrived. Similar frustrations solved when realised that my HDMI ports seem to be arranged A,D,C,B rather than A,B,C,D. Beautiful picture will now set to emulating your set up with Plex etc before moving on to distributing to link rooms.
Wow, wish i understood all of this and that Elephant did Sydney house calls.......
While my system all works, have never been able to get linkplayer to work successfully. Beoport and BM link work fine for now..though im sure the possibilities with linkplayer are endless.....
Best Wishes
David
well I do have rellies in Sydney ....
and a recent ebay purchase bombed (unpostable?!?!?) but the seller has offered to keep it if I call for a pick-up ....
however happy to talk on the 'phone (please don't call tonight ... I am into my second glass of red !)
or talk you through via emails :-)
Hello  There Ed/Mr Elephant
Well I wouldn't want to interrupt your glass of wine!!!!
How about you let me know when you are in Sydney next, and if you have time, drop by, I'm in the inner city. My need isn't urgent, Anders Odlund's BM LINK is working for now... but think LInkplayer might be the future proof option, funnily enough, into the future...
I'll be sure to supply red wine, champagne or any wine, should you find time to drop by...
Best Wishes
David
I'd be delighted to do so ... no immediate plans, but I will let you know when plans eventuate
I'm starting to get my system together - having a few problems with Plex9 & EyeTV but will work through these. My query is, which I'm not quite clear of from the Linkplayer config guide, can I get full Beo4/5 control of Linkplayer through the BV7 (have macmini connected to Beoport/BV7 as per linkplayer config guide) without an IR eye attached to the beoport? (ie I want to be able to hit PC on the Beo4 to bring up the linkplayer menu and be able to navigate up and down it etc with the beo4) & if not do I need to get the B&O eye or can I get a cheap and cheerful one that I can also conceal a bit more easily?
thanks
Yes you can control LinkPlayer without an additional IR receiver.
You'd need an IR Receiver only if you had a older TV.
Select Respond to PC via Masterlink in the preferences.
Also you should connect everything, start LinkPlayer and then only configure the PC source in the BV7 menu.
P.
