BTW, not sure if you had seen my wiring set-up that has been posted previously
Great setup...
But do you have the MacBook picture on your link TVs ??
Stefan
Great setup...
Stefan
Thanks Elephant for the wiring diagram - will take me a while to digest but looks interesting.
Phil, unfortunately, from the CM388 product info "Analog L/R audio outputs are not available when the audio input is Coaxial" so I can't see a way of avoidiing the DAC
D
Yes right. You will need a HDMI device to convert digital audio.
Stefan
Thank you for posting - this is very helpful.BTW, not sure if you had seen my wiring set-up that has been posted previously
I wonder if you could explain the connections between the connections out of the RF Link Amp at 3-4-6 o'clock -> 2 into DVB-T and 1 into the BV8.
Also, where is your primary aerial input?
Thanks in advance.
AP
Dylan, do you own that Mac mini already or you're going to buy it?
p.
Nope, not yet, BV7 doesn't even arrive for another couple of weeks! Am feeling more confident that I can get it to work so may well get one soon after the BV7 arrives. Credit where it's due - one of the main drivers for me getting it is the excellent Linkplayer interface - so please add my thanks to all the others on the site.
Dylan
Yes, should work. It`s similiar to my setup descibed above. But why connect the mini`s coax out to the CM-388 ? It`s just a passthrough, you can connect it directly to BV7-40.
Good point thanks - might save a few $$ on my cable/converter bill!
BTW the DAC should be able to detect automatically PCM, DD, DTS - passthrough and convert to analog stereo without delay
Anyway of seeing this from technical spec of a DAC?
thanks
Nope, not yet
It is very likely that a new version of the Mac mini will come very soon. This new version either have an HDMI socket, or will send audio through the mini-displayport. In that case you won't need the separate DAC. I suggest you wait for the Mac mini update.
p.
Yes - I've seen rumours of this - as you say may well be sensible to wait for this
Nope, not yet
p.
Would be very helpful.
Stefan
Great setup...
Stefan
Thank you :)
Correct, I do not get the MiniDisplayPort/HDMI output through to the link rooms; that is why I liked the idea someone had of trying to have duplicate paths (one digital, one analogue) from a MacMini or an Apple TV -- the unanswered question is whether those Apples would "broadcast" simultaneously on both connections ......
Thanks in advance.
AP
The danger of putting in too much detail :-)
I find the B&O RF box complicated to understand (I am no electrical engineer).
This is how I put it together and it seems to work:
-- observe the small dotted RF cable that appears from the wall by the BeoSound 4 - this is my primary aerial coming from the roof
-- that feed is split, one half goes to the right and is the digital input for the DCB-T module
-- the other half goes left and is the input into the RF amplifier (3 o'clock)
-- then from the RF output of the DVB-T there is a cable that goes to the RF amplifier (4 o'clock)
-- then from the RF amplifier there is a path to the old analogue receiver in the BV7 (6 o'clock)
The B&O RF Amplifier has 6 taps:
Mod. IN which is my 4 o'clock
Aerial IN, my 3 o'clock
TAP 1, my 6 o'clock
TAPs 2, 3 and 4 feed the link TVs and the eyeTV
I hope that helps
(there is a FAQ on this site for the amplifier, but it took several emails between myself, Keith and Phillipe for me to get this all working)
