BeoWorld Bang & Olufsen Forum
Bang & Olufsen Discussion Forum
Welcome to BeoWorld Bang & Olufsen Forum Sign in | Join | Help | Main website
A8 Headphones
Last post 10-26-2007, 13:06 by KingStreet. 3 replies.
  •  10-23-2007, 21:56 57704
    A8 Headphones
    How can I tell if my A8s are real or fake?
  •  10-24-2007, 0:44 57708 in reply to 57704
    Re: A8 Headphones
    post a picture
    BS9000-BL8000-BS2 et bientôt autre chose.
  •  10-25-2007, 16:13 58233 in reply to 57704
    Re: A8 Headphones
    If you bought them on ebay for $40, they are probably fake. Find someone that has a real set and compare the two. The differences will show when side by side.
    Joe
    Its not just a product, its a way of life...
  •  10-26-2007, 13:06 58419 in reply to 58233
    Re: A8 Headphones
    Fake A8's have a silver end cap on the "arm" - at least all the ones I've seen so far.
    Other diffferences ( apart from crappy sound !! ) are the writing is not printed cleanly, the wires are lower spec, the leather pouch is plastic, and there is noticeably low grade packaging.
    As per the earlier post, with any online BeoBargain, if its too good to be true ( and £40 for A8's is too good to be true ) its generally because its a rip off.  Or stolen.
    Bang & Olufsen of King Street - Manchester,UK.
    SKYPE - beokingstreet
View as RSS news feed in XML
