Can I connect Playmaker to Beolink Passive?
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
GillB
GillB posted on Sat, Nov 11 2017 6:39 AM
I have an old wired system with a Beolink Passive connected to a speaker system, controlled by a Beosound 9000.
Sadly, the Beosound 9000 has died (will not turn on, no standby light at all, have checked the powerpoint).
I have a Playmaker that was also hooked into the Beosound 9000.
Would I be able to hook the Playmaker directly into the Beolink Passive to use the speakers? Please let me know how!
If not, any ideas on the best "fix", or should I replace with a wireless system?
Any advice appreciated. Thanks.
Andrew
Frinton, UK
Silver Member
Andrew replied on Sat, Nov 11 2017 8:20 AM
Hi, I believe you can - you need an RJ45>Powerlink Cable - if you have one give it a go, if not then Steve at Sounds Heavenly will be able to advise
Millemissen
Flensborg, Denmark
Hi GillB and welcome to Beoworld.
If you order the cable from a B&O dealer, this is it
It is the socalled fully wired PL cable.
As written above, you can also get it from the site sponsor Steve SoundsHeavenly.
Page 1 of 1 (3 items) | RSS
