Beomaster 7000 tuner and Aux connection
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
j_lowry
Silver Member
j_lowry posted on Fri, Nov 10 2017 4:34 AM
I recently purchased a Beomaster 7000 (minus Beolink 7000) and I'm having no luck getting the tuner to work. I've done some recapping on a Beomaster 5000 and Beogram 4004 with great results but the tuner section is beyond my capabilities.
I'm using a Beo 6 to do the tuning by using the Beo 4 commands to choose a station and that appears to work: The display show "F", followed by the numbers as I type them in so I believe it is accepting the command but I only hear static. I can occasionally get a quick bit of sound as I tune to a new station but it quickly goes to static. All the preset stations are static only as well. Are there any recommended checks I could run on the tuner to help diagnose? I don't have an oscilloscope or anything beyond a multimeter so I'm wondering if there is a common fail point?
Also the TV/AUX connection sounds bad, no static but the sound is very faint. Is there something different about this connection from the others? I'm using a DIN5 to minijack for testing the unit and listening over headphones. I'm guessing the pinout is different? I want to use this as an output to a masterlink converter and send audio to another room. All other inputs are working fine though
I'd greatly appreciate any help in getting this project up and running!
Guy
Bucharest, Romania
Guy replied on Fri, Nov 10 2017 9:50 AM
j_lowry:
Are you sure that your DIN5 to minijack cable is an output rather than an input?  The L/R pins of the minijack should be connected to pins 1 and 4 of the DIN, in order for it to work.
I am slightly confused by your 'all other inputs are working' comment - do you  mean that other DINs (TAPE 1 and 2) are working as outputs?
Have you tried the headphone socket?
EDIT: Welcome to Beoworld, by the way! Smile
j_lowry
Silver Member
Thank You for the quick reply!
For all my listening so far I've used the headphone socket on the Beomaster 7000. I have some Speakerlink cable on order from Sounds Heavenly for connecting to some Penta mk 1s but for now I'm just listening on headphones.
For testing the inputs (CD, TAPE1, TAPE2, PHONO, TV/AUX) I have a minijack to 5 pin Din I'm using to connect to a source (portable cd player or iphone) to verify the inputs are ok. Eventually I plan to connect a CD 7000 and my Beogram 4004 as sources. The only input (other than the radio) I'm having having trouble with is the TV/AUX connection.
Here is where I'm confused on the TV/AUX connection: As I understand it was originally for connecting to a MX3500 TV. This was to allow the sound from the TV to be played through the audio system. But did it also allow for audio inputs from the Beomaster to be played through the TV speakers? That would mean it has 2 way connectivity.
The TV/AUX connection is also used to connect to a Beolink Converter (1611) for use in a Masterlink system. I had intended to do this and use the Beomaster 7000 as an audio master in a masterlink system, but maybe that was a wrong assumption. Maybe the Beolink converter in this case is only 1 way and the Beomaster can only receive audio over the masterlink system, essentially becoming a link room?
tournedos
Finland
TV/AUX is on a different Datalink bus, but other than that, it should behave exactly the same as the tape connections - both in & out.
If TP1 and TP2 work normally with your cable, I suppose there must be some internal problem in the Beomaster. The simplest case might be cracked solders, if somebody has yanked on the cable in the past.
--mika
j_lowry
Silver Member
j_lowry replied on Fri, Nov 10 2017 11:51 PM
Yeah, now that you've said it I realize my mistake. It's been a long time since I've thought about how to hook up a tape deck. I'll check the board this weekend to see if the AUX connection joints are cracked.
I got a closer look at the tuner board and found some cracked traces around were one of the mounting bolts goes through the board. It looks like some pressure was applied to the end of the board and cracked them, I will try to repair them this weekend and hopefully that will fix it.
BTW, are there any Beo4 command sequences to select the AM band or tune to an AM station? I've only found the FM command sequence. Is there a seek function as well (both AM and FM)?
Page 1 of 1 (5 items) | RSS
