Amazing choice of pre-owned Bang and Olufsen
Got a problem with the Forum?
then please email me at keith@beoworld.org with details
Cleaning of stylus (general use of cleaning products) for Beograms
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
Ben_S
UK
Ben_S posted on Wed, Nov 8 2017 7:20 PM
Dear all
I was hoping to gauge your opinions on the use of 'stylus' cleaning fluid for MMC and SP cartridges.  Do you use something similar or should I stick to the brush provided in the box for the stylus?
I have a lot of Beograms around so it would be useful to know your thoughts on this. I have also just had a couple of my cartridges rebuilt by Axel's protege so I would like them to last if possible!
Ben
Peter
Earsdon
Peter replied on Wed, Nov 8 2017 8:19 PM
The problem with stylus cleaner is if it gets up in the suspension, it can damage it. I used to use it but now use a Flash Magic Eraser as, looking at the diamond with a high powered binocular microscope, this seems to get the stylus the cleanest. One just dabs the diamond down and then up and the results are great. No solvents.
Remove the brush on the Beogram 8000 and burn it - it is work of the devil!
Peter
9 LEE
Eastbourne, UK
ONLINE
9 LEE replied on Wed, Nov 8 2017 8:31 PM
Peter:
Or sell it on eBay for £10, like I've seen done! Huh?
I'll try the magic eraser - thanks for that tip Peter.
Ben_S
UK
Ben_S replied on Thu, Nov 9 2017 8:14 AM
Peter, thank you.  I will try a magic eraser!
I have heard that stylus cleaner can damage the suspension so will stop that!
Page 1 of 1 (4 items) | RSS
