Beolab Penta 1 Amplifier problem
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
stanpan
stanpan posted on Sun, Nov 5 2017 8:12 AM
Hello !
There are problems with the amplifier. One work great, another one faulty.
After a while, it sounds like a contact error(
crackling sound), then it stops, the led will be orange.
After restarting work fine
It is when it turns off after 5 minutes, when it turns off later. (work 5-6 hours, and the led goes orange, and not work)
What could be the problem?
I use my Penta from PC.
Best regards
Dillen
Copenhagen / Denmark
Welcome to Beoworld!
- Cracked solder joints at the driver transistors and where the ribbon cable from the front panel meets with the amplifier board.
- Bad capacitors.
- Bad idle current trimmer.
- Any combination of the above.
stanpan
Hello!
Many thanks for fast reply!
if I use it to service, can it be worse?
Can be bigger damage?
Steve
Dillen
Dillen replied on Sun, Nov 5 2017 12:36 PM
It may just stop working altogether at some point, or it may go with a bang and cause more damage.
That depends on where the problem is.
It will not get better by itself.
stanpan
Thank you for your reply.
In this case I will not use it, just after the service.
Are there easily replaceable components or are specially made difficult to obtain?
Dillen
I doubt you will have to replace any components, other than perhaps a trimmer or two (and then adjust).
But all electronic components in the Penta amps are fairly common.
stanpan
This is good news thank you for the reply Martin.
All the best!
Steve
Page 1 of 1 (7 items) | RSS
