Click here to see Christmas Prizes
Beolab 8000's as PC speakers
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
dbfreq
dbfreq posted on Sun, Oct 29 2017 2:07 AM
I am looking for the best way to integrate a pair of Beolab 8000's as my PC speakers.  I am smart enough to know ask ppl like you for advice.  Should I get a DAC and preamp?  I really appreciate any advice to keep it clean and masterful at low volume levels.
TWG
TWG replied on Mon, Oct 30 2017 4:34 PM
Welcome to Beoworld! :)
If you have a "noisy" soundcard in your PC or if it makes plopping sound when switching on/off you shoud use some kind of DAC / preamp / USB-Audiointerface. They give you more comfort regarding volume control, too.
If you have analog outputs on your PC you could get an old tc electronic Desktop Konnekt 6. They are extremely cheap nowadays, provide very good quality and control. If you have a firewire connector on your computer you can use it as an audio interface, too:
http://www.tcelectronic.com/desktop-konnekt-6/
A similiar but pure digital solution exists from tc electronic and is called BMC-2. It's a DAC/preamp/Monitorcontroller and accepts various digital input formats:
http://www.tcelectronic.com/bmc-2/
Otherwise you can use every USB-Audiointerface that fits your needs:
https://www.thomann.de/gb/usb_audio_interfaces.html?viewMode=block
You just should have a look if it has a knob for output volume control. Than you don't have to use software to adjust the volume of your speakers. A simple and powerful interface is e.g. Novation audio hub.
or just use monitor controllers between your computer and Beolabs:
https://www.thomann.de/gb/search_dir.html?sw=monitor+controller&viewMode=block
Steve from soundsheavenly can sell you every cable you need.
Page 1 of 1 (2 items) | RSS
