Beogram 6000 arm doesn't move to the left
Not Answered This post has 0 verified answers | 2 Replies | 2 Followers
FX
FX posted on Wed, Oct 25 2017 1:08 PM
I am restoring a Beogram 6000 when a new problem showed up. The arm stopped moving to the left. Works perfect when moving right.
I tested the Motor drive Board and got the folloing results.
The technichal diagram (attached) provides the following values for the motor voltage:
Action     P5(2)     p5(4)
>>            1.4v      13.5v
<<         13.5v       1.4v
>            1.4v        5.5v
<            5.5v        1.4v
What I measure is
Action     P5(2)     p5(4)
>>         14.7v      14.7v
<<         12.5v       1.8v
>            6.3v        6.3v
<            4.4v        1.8v
It seems consistent as the Motor voltage (p5(2) - P5(4)) is 0v when there is a > or >> action.
Before I change all the possible transistors or  diodes, I wonder if anybody could lead me to the faulty component. I suspect TR19-26, but I'm not sure.
Thanks for your help.
FX
ProGram
59269 Beckum, Germany
Hi, I think the transistors 21 and/or 22 might be faulty, or the parts around there. Or bad solder joints. With a 4002 I think, i experienced a short to ground coming from a mounting point, that is in the near of one transistor contact.
Chris
FX
FX replied on Sun, Oct 29 2017 11:11 AM
Thanks Chris for looking into this.
I'll start there and keep you posted to see if your predictions come true.
FX
Page 1 of 1 (3 items) | RSS
