Click here to see Christmas Prizes
Beocenter 2300 door belt
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
lausvi
Helsinki - Finland
lausvi posted on Tue, Oct 24 2017 7:29 PM
Hi.
Couple of years ago I bought a Beocenter 2300. After a year of two the doors started having troubles opening all the way, so I bought a new (cheap) belt from eBay, replaced it (along with the CD clamper's belt) and everything worked fine.
Fast forward to last week, and the doors stopped moving at all. I opened the unit and the belt was broken. It was also very much crackled all thrue. Ok, it was cheap!
I am now looking for a new belt. The cheap one I had had a round profile, while many I see on eBay mention them being square. Which one is correct? Was the round one I had incorrect from the start? Any recommended sources (Martin?)?
Weebyx
Denmark
Weebyx replied on Wed, Oct 25 2017 9:52 AM
The original are round belts, but if you did not clean the guide below the glass doors, then they might be to heavy to drag for the belt/motor, and the belt will wear out earlier.
There are some grease of some kind on the guides below, I haven't found any good substitute for them, I just clean it and use some silicone and rub it on the guides after cleaning them from old dust and dirt.
Martin probably has the correct belts. PM him.
/Jacob
Page 1 of 1 (2 items) | RSS
