Click here to see Christmas Prizes
Replacement for 4700uF 16V power supply caps ?
Answered (Verified) This post has 1 verified answer | 3 Replies | 0 Followers
Weebyx
Denmark
Weebyx posted on Fri, Sep 29 2017 9:33 PM
In the earlier beomasters, there is used big alu caps for the power supply.. Can these be exchanged for the same types of "plastic" caps used in the newer BS2300 for instance ?
They have the same values, but are there something special about the alu caps, other than the footprint does not match 100%. The alucaps has a center plus pin and three ground pins around it.
/Jacob
Weebyx
Denmark
Answered (Verified) Weebyx replied on Mon, Oct 2 2017 10:05 AM
Verified by Weebyx
Thanx guys...
The new cap worked perfect, and only 1 of the legs were actually in use, so no need for jumpers :)
/Jacob
chartz
Burgundy, France
chartz replied on Sat, Sep 30 2017 2:17 PM
No, nothing special, you can go ahead Smile
Jacques
tournedos
Finland
But be careful, sometimes the PCB design relies on the negative pins being connected together by the original cap. You may need to add some jumper wires.
--mika
Weebyx
Denmark
Verified by Weebyx
Thanx guys...
/Jacob
Page 1 of 1 (4 items) | RSS
