Beoplay V1 software update 1.0.11.37484
Answered (Verified) This post has 2 verified answers | 32 Replies | 3 Followers
madskp
Denmark
madskp posted on Fri, Sep 29 2017 5:02 PM
I was suprised yesterday that my Beoplay V1  presented me with the software update 1.0.11.37484 dated 01-09-2017. The release notes only says: Your TV is updated with new software.
Does anyone know what's in this software release or if there is any know problems with it before i install it?
In a way I'm impressed. The TV is over 5 years old and still getting updates.
Thanks in advance
Aussie Michael
Melbourne, AU
Verified by madskp
I think BeoMegaMan outlines the update in here....
http://forum.beoworld.org/forums/t/27718.aspx
kallasr
Germany
Verified by Emil
Unfortunately there is only the old version from 2016 for download...
Versie: 1.0.11.37447
Ralf
Beosystem 4 with Beolab 7-6 on table stand (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Sony 55W905A. BeoVision 4-50 HD ready (D9) with Beosystem 3 MK I with Beolab 7-2 on table stand (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Sony VPL-HW55 projector for cinema mode. Beosound 9000 MK3 on horizontal wall bracket. Beosystem 7000 with Beolab 5000 Speakers. Loewe TV with Beolab 6002 and Beolab 11 (all white). Beocenter 6-26 white on motorised stand. In storage: Beolab 5000/Beomaster 5000.
Millemissen
Flensborg, Denmark
Anyone who installed the update and uses Deezer?
Is Deezer HiFi already an option on these tv's?
https://www.deezer.com/da/devices/tv
(scroll down a bit).
Also see this thread:
http://forum.beoworld.org/forums/p/26602/213288.aspx
MircoHH
Germany
I installed the update. Deezer isn't working anymore. There is just a black screen....
kallasr
Germany
Same here. But we use Deezer on our Sonos connected to the Beosystem 4. Better integration with i-devices...than using a TV.
pweber
pweber replied on Tue, Oct 10 2017 5:24 AM
Tonight in Germany. But did not got the time to check what‘s new (if ever).
Harry
Harry replied on Tue, Oct 10 2017 9:04 AM
My BV11 was updated this morning. Deezer works again directly from the remote control.
Millemissen
Flensborg, Denmark
Harry:
Same here - maybe I should consider reactivating my old Deezer Account ;-)
Then again - now I can start Spotify Connect on my Essence and listen on my V1 in the other room....
....either by joining-in or by using the app.
For people with e.g. a BV11 as their main/only system it is great that they reestablished Deezer support - after the Spotify app failure.
which other company would do that for a 4-5 year old tv?
Here is Spotify Connect playing on my V1:
Click the pic!
pweber
pweber replied on Wed, Oct 11 2017 5:44 AM
I thought one of those latest update solves the problem of playing Losless Apple Audio files (m4a using ALAC) with my BV11.
When trying to play such a file my BV11 freezes.
Files are on my Synology NAS. Refering to https://www.bang-olufsen.com/~/mediaV3/Files/User-Guides/BeoVision11/Supported-Formats/Supported_formats-pdf.pdf it should work -or am i wrong?
jans
Belgium
jans replied on Wed, Oct 11 2017 8:26 AM
Great Software update indeed!
I am really happy with the fact that we can now enjoy Spotify in multi-room across my Essence in the kitchen, and the V1/BL9's in the living room. Well done B&O.
I will now have to think whether I will cancel my Deezer subscription or not. I subscribed to Deezer, next to Spotify, to have multi-room capabilities. I can do the same now with Spotify!
Deezer offers the advantage of having a nice in-app experience with the B&O App (I am a beta user). Spotify still requires to work with two apps, or the Spotify App and the BeoOneRemote to join. So it is a bit less user friendly. On the other hand, I do like the spotify curated playlists better...
Choices, choices, choices,...
A bit of a related question: does B&O now also allow Spotify Connect in Multi-room between Essence and A6 or M5? Or is this not possible yet? I recall there were restrictions imposed by Spotify, which did not allow this. In case it is possible, I might go for an A6 or M5 in my study, and remove my Sonos installation
Jan
Harry
Harry replied on Wed, Oct 11 2017 8:27 AM
In the list of supported formats I see no support for ALAC. Data with the suffix m4a are not absolutely ALAC.
Hiort
Sweden
Hiort replied on Wed, Oct 11 2017 8:28 AM
Harry:
My BV11 is also updated but the Deezer just freezes on the startupsccreen. Any advice?
Millemissen
Flensborg, Denmark
No, mine is working - just tried.
Is not very responsive, when you do a search - but one can get used to that....I guess.
Did you try to reboot the BV?
I did not do it/have to do it - but worth a try.
jans
Belgium
jans replied on Wed, Oct 11 2017 10:21 AM
Hello Hiort
I had a similar experience the first time I tried to launch Deezer.
However, it worked when I tried the next day, without doing any specific changes. Nevertheless, I find the Deezer App on the V1 very slow and not userfriendly. I prefer joining the V1 to Deezer on my Essence, using the App. Works much faster!
pweber
pweber replied on Wed, Oct 11 2017 9:27 PM
You‘re right. There‘s nothing about Apple Lossless.
So i think i ripped my CDs Lossless and the BV could not play these. So sad.
Fansastic
The Netherlands
Deezer on my V1's not working, just black screen. Trying for several days now and sometimes the message "service not available" appears, somethimes just nothing.
Deezer on Horizon and Moment is working just fine so no internet thing. Any ideas what can cause this? For my V1's Deezer is not that important because they join in on multiroom play from Moment, but strange that some of the members have no problem activating Deezer and others seems to just cannot get it to work.
Dyssegaard
Before I re-activate my Spotify Premium account I would like to know if the new Spotify Connect feature on V1/BV11 will work with a Beoplay M5 in a multiroom setup. Has anyone tried this?
Best regards - Dyssegaard
Living room: Beovision 11-40, Beolab 8000 (front), Beolab 3 (back), Beolab 2 (sub), Apple TV 4, Chromecast. Dining room: Beoplay M5. Home office & garden: Beolit 12. Travel: Beoplay H8, Beoplay A1.
Page 2 of 3 (33 items) < Previous 1 2 3 Next > | RSS
