LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 07-03-2009 7:57 PM by Dave. 14 replies.
Page 1 of 1 (15 items)
  • 07-02-2009 11:39 AM
    • WDPE
    • Not Ranked
    • Joined on 04-02-2009
    • Posts 4
    Beolab 6000 distorted bass
    Hello everybody,
    I've been using a pair of beolab 6000 speakers with a beosound 3000 for over 7 years without having any problems or changing the setup in any way.
    However, recently, when I turn up the volume just a bit higher then the standard playing volume, the lower sounds seem distorted.
    The sounds resembles a sort of resonance, but this isn't the case. Both speakers seem to have got the problem.
    Any thoughts?
    Kind regards.
  • 07-02-2009 12:41 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,207
    Re: Beolab 6000 distorted bass
    Slide up the front cloth grilles and gently pop them off,
    Then play some music at higher volume, and you should see the bass drivers flapping around like a butterfly in a whirlwind.
    It will be the driver rubbers split. You will need four, probably.
    Seems to be happening quite a lot to the older ones now - i always check ours as a matter of course.
    Lee
    Smile
  • 07-02-2009 12:59 PM In reply to
    Agree with Lee. I've just replaced a set and it's not the first I've done.
    Regards Graham
  • 07-02-2009 1:01 PM In reply to
    The bass drivers from the beolab 6000 looks like a cheap car speakers.
    Why didn't the make a motification for these drivers?
  • 07-02-2009 5:36 PM In reply to
    koning:
    I think that statement is an insult...............to cheap car speakers!!
    Regards Graham
  • 07-02-2009 5:48 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,207
    I must agree.  Whichever engineer had that plonked in his hand to give the seal of approval to obviously didn't go much on aesthetics.
    They're push fit connectors on the back too - not even soldered!  In fact, they connect just like cheap car spe.....    hey, hang on!
  • 07-02-2009 5:51 PM In reply to
    In common with a number of B&O speakers, the sum of the parts works rather better than the individual items might suggest. The quality of the drive units is however disappointing as the longevity is not that great. The upside is that they are cheap to replace!
  • 07-02-2009 6:17 PM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 949
    • Gold Member
    Peter :
    Than it should be a nice experiment to exchange all the chassis with real(!) high end speaker chassis!? Perhaps than the Beolabs will blow you away!?
  • 07-02-2009 8:10 PM In reply to
    • Dave
    • Top 50 Contributor
    • Brisbane, Australia
    • Posts 2,323
    why do they use rubbish drivers??
    I had a look at my beocenter1 speakers the other day and yeah wow, really rubbish cardboard and foam... i can't say the same for BL4000 though they seemed like much better quality drivers.
  • 07-02-2009 9:03 PM In reply to
    Dave:
    Ker-ching the almighty $$$ Devil
    Made in China
  • 07-03-2009 4:07 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Yes it is a pity with the 6000, and that is what prevents me from buying a pair. I love my BL4000 (first prize a year ago Big Smile ), they really seem a perfect mix of sound, design and built quality.
    br
    Chr
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 07-03-2009 4:25 AM In reply to
    A friend of mine had the same problem after transporting his 6000. We removed the cloth and we just had to touch the driver and it poped back in place - and that was sorted.
  • 07-03-2009 6:01 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    What about the driver units in the Beolab 3500, does they have the same problem?
    br
    Chr
  • 07-03-2009 10:18 AM In reply to
    That's why non b&O people say....you pay for it design
    Maybe they are rightHmm
  • 07-03-2009 7:57 PM In reply to
    • Dave
    • Posts 2,323
    koning:
    I think is certainly is the case with these speakers. Yes they are not bad speakers, but... not if you're choosing between them and 4000's. So B&O did make these speakers to a price, but seriously, how much do good drivers cost to use when they are building it from freaking anodised aluminium???
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
