Click here to tell us about your new email address
Beogram 4500 tone arm service
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
Simon Lawrence
London
Simon Lawrence posted on Sun, May 28 2017 12:58 PM
Just been passed a  beogram 4500 with a dropped tone arm.  Delighted to finally own a beogram myself (bought my son a 1000 for his birthday)
There is no cartridge, but it powers up perfectly and tracks across when the start button is used internals are very clean and all seems in order.
I have downloaded the manual and been through it but it is not obviously an adjustment issue, but it will not sit level with the second arm.
There is no vertical activation in the tonearm, which i assume either comes through the white platic rail underneath or the side arm.
Would be hugely gratefull for advice on this and source of cartridge.
Photo attached
Many thanks
Simon
Saint Beogrowler
Saint Paul, Minnesota
Probably the horizontal white plastic bar that holds the tonearm up or down has slide out of position with the wire running perpendicular that's controls it.
Slide your tone arm to the right, the wire coming from the center of the table going up should make contact with the white bar as seen in the photo
If my explanation is confusing, post a picture from above looking down and I can draw on it.
Peter-
joeyboygolf
Ely, Cambridgeshire, UK
The actuation lever is the wrong side of the white plastic bar.
It needs to be to the rear of the bar not in front of it.
Unclip the rear mounting rod (chrome plated bar) from the right mounting, lift the carriage so the lift actuator is clear of the white bar, pull the white bar forward and replace the chrome shaft in it's mounting with the actuator behind the white shaft.
Your problem should be solved!
Regards Graham
Simon Lawrence
London
Peter and Grahame
Thank you both, I now understand how it works work and the spring to retain the white arm had come undone, simple fix.
Now to get a cartridge.
Thank you so much for showing the way
Simon
Page 1 of 1 (4 items) | RSS
