Click here to tell us about your new email address
CD door problem, Beocenter 8000/9000
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
JanKaj
JanKaj posted on Sat, Apr 22 2017 7:57 AM
Problem is that the only moves some inches/cm - sometimes a bit more.
Wires are ok. Can manually operate door by turning the spindel.
Rails cleaned and and operated manually nothing can be noted.
It makes no difference where the door is - half open/closed, fully open/closed.
Casettedoor works fine
Saint Beogrowler
Saint Paul, Minnesota
Belt?
You could try swapping the deck's door belt to the cd side and see if that changes anything. Or maybe it needs a hint of lube.
Peter-
Page 1 of 1 (2 items) | RSS
