Click here to tell us about your new email address
Remove the speaker grill on a Beolab 2000
Answered (Verified) This post has 1 verified answer | 3 Replies | 1 Follower
beoaus
beoaus posted on Mon, Mar 27 2017 11:40 AM
Hi All,
I have Beolab 2000 that sounds rather distorted. I suspect water damage, Is anyone familiar with removing the speaker grills safely so I can inspect inside?
BTW. I did download the service manual, though, a disassembly process is presumed rather than explained.
Thanks beoaus.
Stoobietoo
Exeter, Devon, UK
Verified by beoaus
It is really easy. They slide up and off by sliding them up from the bottom. Carefully slide a credit card in between the bottom of the grille and the grey plastic case. Wiggle it up and down and the grille will start to slide up a little. Once you you have loosened it it will slide right up and off.
Stoobie
Stoobietoo
Exeter, Devon, UK
Verified by beoaus
Stoobie
beoaus
beoaus replied on Wed, Mar 29 2017 10:20 AM
Very easy, once you know.
Thank you, beoaus
Stoobietoo
Exeter, Devon, UK
beoaus:
Sorry if I made it sound so easy you should be able to work it out yourself. I only know to my cost as I dented one​ grille trying to get mine off.
I was so surprised at the ease they​ came off when I knew how.
Stoobie
Page 1 of 1 (4 items) | RSS
