Click here to tell us about your new email address
Beolit Parts
This post has 9 Replies | 1 Follower
the_o_master
Posts 694
Silver Member
the_o_master Posted: Sun, Mar 19 2017 1:28 PM
Some time ago I bought a convolute of Beolit radios for spare parts. I used it to finish few of restorations of my nice Beolits. Now I am finished and I do not need those parts anymore. I made few pictures today and you can look to them, if you can find anything for you. If you need detailed pictures, please write me back.
The price? You can decide by your self (anything you will to pay for it) Smile
Beer
Vintage Bang & Olufsen
Ben_S
UK
Posts 542
ONLINE
Ben_S replied on Sun, Mar 19 2017 1:44 PM
Have you got any of the grey pegs which go in the bottom of the plate? (Where the screws are here)
the_o_master
Posts 694
Silver Member
Hi Ben,
yes I got few grey pegs too but I used them all for my Beolits. There is only one more grey peg and 20-25 of the black ones (they have same dimensions but different color)...
Stonk
Marlow, Bucks, UK
Posts 2,055
Stonk replied on Mon, Mar 20 2017 11:24 AM
Ohh, do you have of the ferrite rod plastic clips that support the rod? I have a radio with a floppy ferrite rod. I think they may be identical but I'm missing the one on the left.
Thank you!
If you think nobody cares, try missing a couple of payments.
the_o_master
Posts 694
Silver Member
thanks for your interest. I am not sure which part you are looking for exactly. For which Beolit model is it? Do you have maybe a picture or even better the part number from service manual?
Regards / Theomaster
Stonk
Marlow, Bucks, UK
Posts 2,055
Stonk replied on Tue, Mar 21 2017 9:51 AM
Thank you Theomaster.
It is the 70's Beolit 700. Item No. 64 Part number 3152052
I also have a few others like the 707 with the usual missing volume & tone sliders so if by chance you have any of those too.
Many thanks,
Steve
Mark
Malvern
Posts 334
Mark replied on Wed, Mar 22 2017 1:42 PM
Do you have an extendible antenna, the one that extends out the top of the case. If so, I'd love to give it a good home.
Mark
the_o_master
Posts 694
Silver Member
Stonk:
Many thanks,
Steve
Hi Steve,
I finaly found some time to look to the parts. Yes, I have few of those ferrite rod plastic clip. See pictures, are you looking for those?
I found also few of those volume & tone sliders but they are all either broken or already repaired :-(
Anyhow I can send them to you and you can try to use them...
Best regards / Theomaster
the_o_master
Posts 694
Silver Member
Mark:
Mark
Hi Mark,
no, unfortunately I do not have antennas anymore Sad
BR / Theomaster
Stonk
Marlow, Bucks, UK
Posts 2,055
Stonk replied on Mon, Mar 27 2017 10:47 AM
Brilliant, thank you. I'll send a PM.Smile
Page 1 of 1 (10 items) | RSS
