Click here to tell us about your new email address
Beogram 1202
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
598974
598974 posted on Tue, Jan 31 2017 7:19 PM
Hi all
I have had my 1202 from new. Bought it in 1970 and just taken it  out of retirement. Been in box for 7 years. It works intermittently in all modes. The pickup arm will only move now and again and the drive belt keeps coming off. Perhaps I need a new belt? Where can I get a new one? Also the round centre pop up for 45s is stuck down. Any way to get it up again?
Any advise will be greatly apreciated and thanks in advance.
Brian
Peter
Saint Paul, Minnesota
Peter replied on Tue, Jan 31 2017 10:09 PM
I believe to get the 45 adaptor up its like the bg3000, pushdown-turn-release. "Dillan" Martin has belts now, they are great.
Peter-
598974
598974 replied on Tue, Jan 31 2017 11:17 PM
Thanks Peter. It used to operate like you say, but it is stuck in down position.
Regards
Brian
Søren Mexico
Mexico City
A little TLC is needed, open the deck and clean off old hard oil and grease, lubricate thoroughly, also the 45 adapter will start behaving then, And As Peter says a new belt from Dillen
Dillen
Copenhagen / Denmark
Have you undone the transport safety screws?
The belt will often come off if you run the deck with the screws locked.
The center needs a push and turn to pop up and lock down.
598974
Hi Dillen.
Thanks for your reply. Yes the safety screws are undone. I think I will start with a new belt, it's been on there for 46 years. I put a bit a tension on it and it stayed on. Please advise how to buy a new belt from you.
Regards
Brian
Dillen
PM or email me (if any of that works for you - for some users neither seems to work).
Or go here: https://beoparts.com/contact/  (works every time).
Page 1 of 1 (7 items) | RSS
